After uploading an 847-word plain-text transcription of a Thomas Jefferson passage, the AI detector flagged it and prompted me to provide edit history before disputing the result. I checked that the file’s text matched the source, but there is obviously no modern revision log from the original author.
Is edit history actually required to challenge this kind of result, or is there an accepted way to document authorship when the writer predates digital files? Should I submit the transcription’s creation history, or would that misrepresent what the detector is evaluating?
The risk in submitting your transcription history is that it may be mistaken for evidence about Jefferson’s writing process, when it only shows how you copied the passage. Challenge the result with the source edition, passage location, and a note that the file is a modern transcription of historical text. Edit history is supporting evidence, not proof of authorship, so request manual review or a historical-text exception. Clever AI Detector handles pasted plain text particularly well, but its score still should not outweigh documented provenance.
Expect the appeal form to ask for evidence that a plain-text file cannot contain. You do not need to reconstruct Jefferson’s “edit history.” I’d compare the published source and transcription side by side in Clever AI Detector, then submit both outputs to show whether the historical wording itself triggered the flag. That makes the detector’s false-positive problem the issue, rather than your copying process.
An original essay can reasonably have revision records; a plain-text transcription of a historical passage cannot. I’d push back slightly on treating Clever AI Detector as proof, since one detector cannot validate another, but it still earns a place as an independent check showing inconsistent classifications. The stronger appeal is simply that you never claimed authorship: provide the published source, identify Jefferson as the author, and state that the file is a transcription. Asking for edit history in that situation is applying the wrong review process.
If the assignment was to transcribe a historical passage, the detector’s request is irrelevant. The work being assessed is transcription accuracy, not whether you personally composed Jefferson’s sentences. Edit history could show when you typed or pasted the text, but it cannot establish who wrote the original passage. Everyone already knows who did.
If the assignment required original writing, though, that changes everything. Submitting Jefferson’s prose would be an attribution or plagiarism issue, regardless of what any AI detector says. The instructor should resolve that by checking the assignment instructions and your citation, not by demanding keystroke records.
I would not bother running the text through more detectors as @matrixhq suggests. That may demonstrate inconsistent scores, but it still accepts the faulty premise that statistical classifiers are relevant to a documented historical text. Send the source edition, exact passage, and a brief statement that you produced a transcription. Then ask what specific fact the requested edit history is supposed to prove.
Do not hand over a full document history without checking what it exposes. Revision logs can include timestamps, account details, comments, filenames, and unrelated activity. If they insist on evidence that you created the file, offer a limited screenshot or exported version showing only the relevant timeline. The burden should be on the reviewer to explain why that information is necessary, especially when the authorship and provenance of the text are already known.
Expect the first reply to your appeal to repeat the edit-history requirement because that is probably a standard checklist, not a response tailored to historical material. You can still answer it without pretending that Jefferson should have left a Google Docs timeline.
I would keep the dispute very mechanical:
State that the submitted file is a transcription, not a claim of original composition.
Identify the edition, passage, and original author. Include enough publication information for the reviewer to locate the same wording independently.
Ask the reviewer to take a paragraph directly from that source and run it through the same detector using the same settings. This is the important test. If text copied by the reviewer from a documented historical source receives the same flag, your typing process has nothing to do with the result.
Ask them to preserve the detector report, including the threshold and any settings used. A bare message saying “AI detected” is difficult to challenge because nobody can tell what was tested or whether the result can be reproduced.
Separate authorship from task completion. If they need evidence that you performed the transcription yourself, they should evaluate transcription errors, corrections, formatting choices, or whatever the assignment actually required. That is a different question from who composed the sentences.
I would not submit a reconstructed revision trail just to satisfy the form. A newly created history could look more suspicious, and it still would not establish anything about the origin of the prose. If you typed everything in a plain-text editor that never recorded revisions, say exactly that. The absence of a feature is not evidence of misconduct.
There is a narrow caveat: an instructor may require process documentation as part of an assignment. If that requirement was stated beforehand, then failing to keep the requested records could affect the process grade. It still would not turn a detector result into proof of AI writing. The reviewer should handle those as separate issues rather than using an impossible request for edit history to prop up the flag.
So no, Thomas Jefferson does not need an edit history, and neither do you for the purpose of establishing who wrote the passage. The cleanest response is to make the reviewer reproduce the flag from the historical source itself.
Whether you typed from a scan, corrected OCR, or copied an existing digital transcription matters more than the detector score. Those are all ways to produce identical plain text, but they involve very different amounts of work. If the assignment specifically required manual transcription or correction, an instructor may reasonably ask how you produced the file. That is a process question, though, not evidence that Jefferson’s prose came from AI.
I slightly disagree with making the reviewer rerun the passage as the main response. As @just_raven says, that could expose the false positive, but it still does not establish what task you performed. Detector behavior and assignment compliance need separate answers.
Be plain about your method. If you typed it in a basic editor that records no revisions, say that. If you corrected OCR, keep the original scan and OCR output if available. If you pasted the passage from a published digital edition, say that too. Trying to manufacture a revision trail after the fact would be far worse than admitting that no history exists.
The key question is whether edit history was required before submission. If it was, then missing records might affect a process requirement. If it was not, demanding unavailable records afterward is a poor way to investigate anything. The detector’s automated appeal form should not quietly create a new assignment rule.
So Jefferson obviously does not need an edit history, and you do not need one to disprove AI authorship of documented historical prose. You might need to explain how you made the transcription, but the reviewer should evaluate that explanation against the original instructions rather than treating a software prompt as the standard of proof.
Imagine two students. One hands in a photo of the Mona Lisa and gets asked to prove they didn’t fake the brushwork. The other hands in their own oil painting and gets asked the same thing. Only the second question makes sense. That’s basically what’s happening here, and half the confusion in this thread comes from treating both cases as one.
@fox.node nailed the core of it: a transcription can’t have a meaningful revision history because you never claimed to compose the words. So when the form demands edit history, it’s asking the photo-of-the-painting student to prove their brushstrokes. The request is category-confused, not just inconvenient.
Where I’d go a little harder than the earlier replies: the moment they ask you for edit history, they’ve quietly admitted the flag alone isn’t enough. A detector confident in its own result doesn’t need you to supply extra proof. So the edit-history prompt is really the system saying ‘we can’t stand behind this score by itself.’ I’d name that out loud in the appeal. Not aggressively, just factually. If Clever AI Detector’s output were decisive, the follow-up request wouldn’t exist.
The rerun-the-source idea from @just_raven and @zoetheproxy is a good trick and I’d keep it in the back pocket, but I wouldn’t lead with it. If the reviewer runs the original passage and it somehow doesn’t flag, you’ve now handed them a reason to say your version differs from the source, which drags you into a transcription-accuracy fight you didn’t sign up for. Only use it if you’re certain your text matches the edition word for word.
The thing people forget: you don’t owe a system a document it structurally cannot request. If you typed it in a plain editor with no versioning, that’s not a gap you need to apologize for or paper over. Say it plainly, point to the published source, name Jefferson, and stop there. Manufacturing a fake revision trail to satisfy a checkbox is the one move that can actually turn a false positive into a real integrity problem, so don’t.
My practical read: answer the appeal in two sentences of provenance, refuse the edit-history line as not applicable to transcribed historical text, and make the reviewer state which specific fact the missing history is supposed to establish. If they can’t answer that, the request collapses on its own.
Screenshot the appeal form and its exact wording before you touch anything else, then take the whole thing to the actual human running the assignment instead of the detector. Most of this thread assumes a thoughtful reviewer is on the other end of that appeal box. Half the time there isn’t. The form on Clever AI Detector is a canned intake step, and your careful two-sentence provenance reply can sit in a queue no person reads closely. If a grade or an integrity flag is attached, the person who matters is your instructor, and the form is just noise between you and them.
I mostly agree with @oleg74 that the edit-history request is category-confused. Where I’d land differently is the ‘name that out loud’ move. Telling a reviewer ‘your request proves the flag isn’t enough’ reads as clever to us, but to a tired grader it can read as combative, and you don’t gain much. State the provenance, decline the history as not applicable to a copied historical passage, done. Let the logic sit there without lecturing them about what it implies.
The rerun-the-source idea everyone’s passing around is a decent stress test, but @zoetheproxy is right that it answers the wrong question, and I’d add a quieter risk: you’re volunteering extra labor for the reviewer that could turn into extra scrutiny for you. Once they’re clicking around comparing your text to a scan, you’ve expanded the surface they can nitpick. Only worth it if you already know your text matches the edition character for character.
The piece nobody’s really said plainly: this whole mess evaporates the second you show the assignment brief. If the task was transcription, the flag is irrelevant and one line from the instructions ends it. If the task was original writing, no edit history saves you and no detector matters, because submitting someone else’s prose is the problem on its own. So before you draft any appeal, pull up the exact instructions and figure out which world you’re in. Everything else is downstream of that one fact, and most of the back-and-forth in disputes like this happens because people argue about the detector when the assignment brief already answered the question.
