I recently switched to a Mac and can’t figure out the best way to access and use emojis while typing in apps like Messages, Mail, and browsers. I’ve tried searching through keyboard settings but it’s still confusing. Can someone explain the simplest steps or shortcuts to get emojis on a Mac, and whether there are any hidden tricks or settings I should know about?
Fastest ways on a Mac:
System emoji shortcut
• Press Control + Command + Space
• A small emoji picker pops up near your cursor
• Type to search like “smile”, “heart”, “shrug”
• Hit Enter to insert
Works in Messages, Mail, browsers, basically any text field. -
Use the full Keyboard Viewer
• Go to System Settings → Keyboard
• Turn on “Show keyboard and emoji viewers in menu bar”
• Click the little keyboard/emoji icon in the top-right menu bar
• Pick “Emoji & Symbols”
Same panel as the shortcut, but handy if you forget the keys. -
Touch Bar (if your Mac has it)
• While typing, tap the emoji icon on the Touch Bar
• Swipe through categories
• Tap the emoji you want
This one is slower for long messages but ok for quick inserts. -
Text replacements for your favorites
• System Settings → Keyboard → Text Replacements
• Add shortcuts like- “:shrug” → ¯_(ツ)_/¯
- “:lenny” → ( ͡° ͜ʖ ͡°)
Then type the shortcut in Messages, Mail, etc and macOS swaps it in.
iMessage specific trick
• In the Messages app, type a word like “smile”
• After you send text, click “Edit” → “Substitutions” → check “Emoji Replacement”
Then some words turn orange, click them to swap to emoji.
If the shortcut does not work, check:
• System Settings → Keyboard → Keyboard Shortcuts → Input Sources
• Make sure “Show emoji & symbols” is set to Control + Command + Space or something you remember.
That covers pretty much every normal use case on macOS.
If @byteguru gave you the “normal person” ways, here are the slightly more nerdy / alternative routes that might fit better depending on how you type:
Use the built‑in “Press Globe key” trick (for some keyboards)
On newer Apple keyboards (esp. laptop ones), the fn key is treated like a “Globe” key.- Go to System Settings → Keyboard
- Look for “Press fn key to” or “Press Globe key to”
- Set it to “Show Emoji & Symbols”
Now a single tap of fn pops the emoji panel. I find this faster than Control + Command + Space most of the time.
Rely on predictive emoji on iPhone and sync via Messages
If you’re in Messages and do a lot of texting on iPhone anyway:- Type in the conversation on your iPhone, where the keyboard already suggests emojis as you type words
- It all syncs in the same chat on Mac
Not “true” Mac emoji access, but in practice I end up doing complex emoji-heavy stuff on the phone because it is simply faster.
Use third‑party launchers / keyboard utilities
If you’re already using things like:- Alfred, Raycast, or LaunchBar
Many of them have emoji search workflows/extensions: - Type a keyword like
:smilein the launcher - Hit Enter and it pastes the emoji into the active app
This is way more flexible and lets you keep your hands in your normal shortcuts workflow.
Create system-wide snippets with third‑party tools
@byteguru mentioned Apple’s built‑in text replacements, but they’re kinda clunky. Tools like:- TextExpander, Espanso, Rocket (emoji-focused)
Let you type stuff like:thumbsupor.shrugand instantly expand to
or ¯_(ツ)_/¯ in literally any app. The advantage over Apple’s own is: - Better sync
- Easier to manage lots of shortcuts
- Often better search or menus
Menu bar quick access, but smarter
Instead of just using “Show keyboard and emoji viewers in menu bar” like @byteguru said, pair it with:- Keyboard shortcut utilities (like Karabiner-Elements or BetterTouchTool)
- Remap some useless key combo you never use to:
- “Open menu bar emoji item”
It turns the menu bar icon into a pseudo shortcut you actually remember.
If emojis aren’t showing correctly
Sometimes it looks like you “don’t have emojis” when really:- The font in that app does not support the character
- Or the app is old / non-native
Quick check: - Paste an emoji into TextEdit or Notes
- If it shows up there, your system is fine, the other app is the problem
Browsers are usually fine, but some web apps override fonts in weird ways.
Slight disagreement with @byteguru on Touch Bar
Personally, I find the Touch Bar emoji picker almost useless for anything more than tossing a single
in a chat. Scrolling those tiny icons is slower than just using the shortcut and typing the name. If you rely on emojis a lot, training yourself to search by name is actually faster long term.
If you only pick one “habit” to form: set fn to “Show Emoji & Symbols” and force yourself to use search in that popup for a week. After that, it’ll feel natural and you won’t be hunting through categories like it’s 2012.
Skip the emoji hunt and think in “input modes” instead of “where’s the button.”
1. Use inline colon codes almost everywhere
macOS is pretty forgiving with colon codes, especially in chat and web apps.
- Type things like
:smile:,:heart:,:clap:and pause - In many apps (Slack, Discord, GitHub comments, some web chats) it autocompletes to
- In others, it at least lets you quickly search the right emoji when their picker pops up
This isn’t universal, but once you build the habit, you barely think about the system picker at all. It also means you can stay in pure text mode and not break your typing flow.
2. Switch input sources with a hotkey rather than chasing emoji panels
A different angle from @byteguru and @byteguru’s more “nerdy” angle:
If you sometimes type in languages that have their own emoji-heavy keyboards (like certain mobile layouts), you can mirror that mentality on Mac:
- In System Settings → Keyboard → Keyboard Shortcuts → Input Sources
- Bind a simple combo like Control + Option + Space to “Select next input source”
- Add additional layouts or variants that you prefer for symbol-heavy work
You are not getting an emoji keyboard per se, but you shorten the path to whatever layout and character set you like. Paired with the normal emoji panel, this can actually be faster than constantly triggering the viewer.
3. Treat emojis as part of your typography, not stickers
A lot of the “where are my emojis?” pain is actually font behavior:
- Try switching fonts inside the app to something that plays nicer with Apple Color Emoji, like system fonts or San Francisco variants
- Avoid older or super custom fonts for emoji-heavy content because they can fall back to ugly monochrome glyphs or tofu boxes
- If your browser or editor lets you set a fallback font, prioritize Apple Color Emoji so emojis render cleanly alongside text
This is where I slightly disagree with the “just check in Notes” logic. Notes is fine as a test, but if you live in, say, a specific Markdown editor or JVM app, you might need to tune font settings there, not assume the system is “the problem.”
4. Use the emoji popup as a search box, not a palette
Both @byteguru and the more power-user answer already covered the main triggers, so I will not repeat those. The trick that actually changes how usable it feels is how you use it:
- Immediately start typing a word like “party” or “arrow”
- Use arrow keys and Return to select
- Don’t scroll categories. That is the part that feels like 2012.
Once you train yourself to think “open picker → type 3 letters → hit Return,” emojis become as fast as keyboard shortcuts instead of an icon safari.
5. Quick pros & cons of relying on picker-centric workflows
Since the “How To Get Emojis On Mac” angle often misleads people into thinking the panel itself is the main feature:
- Works in basically every native text field
- Consistent behavior system-wide
- Search makes it realistic even for obscure emojis
- Breaks typing flow if you need many emojis in a row
- Awkward in full-screen apps or remote desktops
- Some older or cross-platform apps handle the popup poorly or steal focus
That is why combining:
- colon codes where supported
- a fast picker search habit
- sane font choices
ends up smoother than hunting for new shortcuts or installing too many tools.
Good overview. You framed input modes, colon codes, fast picker search, and font setup well. Pros and cons read true.
Alternative, simpler path: use system Text Replacements. Open System Settings, Keyboard, Text Replacements. Click the plus. Add ,smile →
, ,party →
, ,shrug → ¯_(ツ)_/¯. Works in Messages, Mail, browsers, Slack. Type shortcut then space or Return. No picker, no mouse. Faster for frequent emoji. Syncs via iCloud. Fewer clicks, less context switching. If something fails, restart teh app and try again.
