I just started trying Gemini AI and I’m confused about how to use the main features, write better prompts, and get accurate results. I’ve watched a few videos, but I’m still not sure what I’m doing wrong, and I need simple advice to get started without wasting more time.
Start with one job per prompt. People mess this up a lot.
Bad prompt:
“Help me with marketing, write emails, make a plan, and tell me what tool to use.”
Better prompt:
“You are my email assistant. Write 3 follow-up emails for a web design lead who stopped replying after a quote. Tone is polite. Keep each under 120 words. Add one subject line per email.”
Use this format every time:
- Role
- Task
- Context
- Rules
- Output format
Example:
“Act as a tutor. Explain Gemini to a beginner. I use it for school and work. Use simple words. Give me 5 tips in a bullet list.”
If the answer is weak, do not rewrite the whole prompt right away. Add one fix:
“Be more specific.”
“Use plain english.”
“Show an example.”
“Cite sources.”
“Ask me 3 questions before answering.”
For accuracy, paste the source text into Gemini and say:
“Answer only from this text. If info is missing, say ‘not in source.’”
This cuts made-up stuff a lot.
Also, use separate chats for separate tasks. One chat for coding. One for writing. One for research. Mixed chats get messy fast.
If you want, post one prompt you used and I’ll clean it up.
Big thing people miss: Gemini is not really “smart” in one fixed way. It behaves differently depending on mode of use. That’s why random YouTube advice feels inconsitent.
@mike34 is right about keeping prompts focused, but I’d push one extra idea: stop trying to make the first prompt perfect. Treat it like a draft. Your real skill is in the follow-up.
A simple way to use Gemini:
- Ask it what it needs before doing the task
- Make it show assumptions
- Check one claim at a time if accuracy matters
- Have it explain why it answered that way
Example:
“Help me compare these 3 laptops. First ask me 5 questions about budget, battery, gaming, weight, and screen size. Then make a table. Mark anything uncertain.”
That usually beats dumping a huge messy prompt.
Also, I kinda disagree with the “separate chats for everything” idea as a hard rule. Sometimes one ongoing chat is useful if Gemini needs your history, like for a long writing project. Just reset when it starts getting sloppy.
For accurate results, use this:
- “What are you least sure about here?”
- “Separate facts from guesses.”
- “Give me a short answer first, then details.”
- “If there are tradeoffs, list them.”
If you want simple practice, do 3 basic tasks first: summarize an article, rewrite an email, compare two options. That’s usally enough to see how it thinks.
