Is It Still Possible To Recover Deleted Files From Hard Drive A Few Days Later?
I accidentally deleted important files from my hard drive a few days ago and didn’t realize they were gone until now. I’m trying to find out if hard drive data recovery is still possible after several days and what steps I should take right away to avoid losing them for good.
Don’t spiral yet. I’ve deleted stuff I cared about, and the first few minutes matter more than anything else. On a hard drive, a deleted file often still sits there for a while. The entry is gone, the data often isn’t. If you move fast and keep your hands off the drive, your odds stay decent.
The big rule is simple. Stop writing to the drive right away. No downloads. No copying random files. Don’t install tools onto it. If the missing files were on your system drive, don’t keep browsing and poking around on it either. When a file gets deleted, Windows or macOS usually marks the space as free. The old data stays in place until something new lands over it. Once overwritten, you’re done. So yeah, stop using the drive. Period.
Figure out which drive you lost the files from
  1. External drive or secondary internal drive: this is the easier case. Disconnect it, hook it up to another computer, and scan it there. You avoid extra writes and keep the situation clean.
  2. Main system drive: this is trickier. I’d boot from a USB stick or connect the drive to another machine before doing anything serious. The goal is the same, keep new data off it while you try recovery.
Run recovery software, fast
This is where most recoveries happen, if the deletion was recent and the drive is still healthy. I’ve tested a few tools and the one I kept going back to was Disk Drill. It scans for files beyond the stuff you only deleted a minute ago, and the preview feature helps a lot. You get to check whether a document, photo, or video still opens before you waste time restoring junk or partial files. The free version lets you scan and preview first, which I liked.
One thing people mess up all the time, do not install it on the same drive you want to recover from. Put the app on a different disk, then scan the problem drive.
Stuff worth knowing before you start
  1. Old-school HDDs usually give you a better shot than SSDs. Recovery tends to be kinder on spinning drives. Even so, some newer hard drives support TRIM, so don’t sit on it for hours thinking the files will wait forever.
  2. If the drive clicks, grinds, or makes weird repeated noises, stop. Software is not fixing a mechanical problem. At that point you’re looking at a recovery lab, not another app.
  3. Don’t run endless scans hoping the fourth one will perform magic. One proper scan is usually enough. After that, you sort results and restore what still looks intact.
I’d keep it boring and methodical. Move fast, don’t write to the drive, scan from another disk, recover to a separate location. People do get files back this way all the time. I’ve seen it work, and I’ve also seen people wreck their chances by installing recovery software right on top of the deleted data. Don’t do tht.
Yes, a few days later is still within the window for hard drive data recovery, if the deleted sectors have not been overwritten.
I agree with @mikeappsreviewer on the main point, stop using the drive. I differ a bit on urgency though. A few days does not automatically kill recovery on a classic HDD. What matters most is how much new data hit the same drive after deletion. If you deleted 20 GB of files, then kept downloading, updating Windows, or editing video on the same disk, your odds drop fast.
A few checks before you scan:
  1. Check Recycle Bin or Trash first. Sounds dumb, still worth 10 seconds.
  2. Look for cloud copies. OneDrive, Google Drive, Dropbox, iCloud.
  3. Check File History, Previous Versions, Time Machine, or backup software.
  4. If the files were on an SSD, chances are worse because TRIM often wipes deleted blocks early. On a hard drive, recovery odds are usually better.
Best move is to make a full image of the drive first, then scan the image, not the original. Most people skip this and then keep stressing the disk. Bad idea. If the drive is healthy, imaging protects you from mistakes. If the drive is failing, stop DIY stuff and send it to a lab.
For software, Disk Drill is fine for a first pass because it previews recoverable files and sorts results in a way normal people can use. Recover to a different drive. Not the same one. Thats where people mess up.
Also, this hard drive recovery tip is worth a quick look: hard drive recovery tips for deleted files
Short version. HDD after a few days, yes, still possible. SSD after a few days, less hope. If the drive starts clicking, stop.
Yep, still possible. A few days later is not some magical deadline, especially on a regular HDD. I’d actually push back a tiny bit on the panic level from @mikeappsreviewer and @codecrafter. Time matters, sure, but drive activity matters more than the calendar. If the drive mostly sat there, your chances can still be pretty decent. If it was your OS drive and you kept using it nonstop, that’s where things get ugly fast.
One thing I’d add that they didn’t really stress enough: deleted files can come back with the original folder structure missing or filenames scrambled. So don’t expect a neat one-click restore. Recovery can be messy, and you may need to sort by file type, size, or modified date to find the stuff you need. That catches people off guard.
Also, before doing a deep recovery, check whether the app that created the file has its own autosave/cache/version system. Office apps, Adobe apps, some video editors, even Notepad replacements sometimes leave temp copies behind. People forget this all the time.
If you do scan, use something reputable like Disk Drill, but be realistic. Previewing files is a huge deal because a file showing up in results does not always mean it’s usable. Recover the found files to another drive, obviously. Not the same one. Kinda wild how many people still do that and then wonder why recovery got worse lol.
And if this was an external hard drive, this might help too: external hard drive file recovery tips and discussion
Short version: HDD after a few days? Yes, absolutley possible. SSD? Much worse odds. If the files are worth serious money or legal trouble, skip DIY and go straight to a recovery lab before you make it worse.
