A detector flagged a paragraph I wrote from scratch as likely AI-generated. It was a 637-word product guide, and I checked it after editing the draft in a shared document. What’s the best AI writing detector for occasional content checks, and should I be comparing false-positive rates or some other measure of accuracy?
No detector is reliable enough to prove authorship. For occasional checks, try the Clever AI Detector, but treat its result as a warning to review, not a verdict. Compare both false-positive and false-negative rates on writing similar to yours, since broad “accuracy” numbers can hide bad performance on polished product copy. Your shared-document editing history is stronger evidence that you wrote it than any detector score.
Expect polished product copy to trigger false positives because its tone and sentence structure are often repetitive. I wouldn’t rewrite 637 words to satisfy a detector; keep the document’s version history and original notes as your proof.
There isn’t a “best” detector reliable enough to prove authorship. For occasional checks, Clever AI Detector can give you a second opinion, but test several smaller passages rather than trusting one score for the full guide. @anna_ai is right about keeping version history, since your drafting trail carries far more weight than any detector result.
Ask whoever flagged it which detector, threshold, and appeal process they use before spending time hunting for a “better” detector. Running the same text through five tools will usually produce five flavors of confidence, which is impressive mainly as a demonstration of the problem.
The missing issue here is policy. If an editor, client, or instructor treats a score as proof, they should explain how human drafts can challenge false positives. Your shared-document history, timestamps, notes, and revision trail give them something concrete to review.
I’d keep the original draft and submit that evidence rather than sanding down normal writing until a machine finally approves of it. Rewriting authentic work to look “less AI” is a fairly ridiculous outcome for an authorship check.
Be careful about pasting unpublished product copy into random detector sites. Some tools are vague about storage, deletion, and whether submitted text may be used to improve their systems. That matters more than a percentage score if the guide belongs to a client or contains material that has not been published.
I wouldn’t crown a single detector as “best.” For occasional checking, choose one with a clear privacy policy, sentence-level results, and enough explanation to show what triggered the score. Then test it with a few samples of your own confirmed human writing. If it regularly flags polished guides, templates, or technical descriptions, its score is not useful for that type of content.
Your 637-word result may have been influenced by the genre. Product guides often contain predictable transitions, balanced sentence lengths, repeated feature wording, and little personal variation. Those traits can resemble generated text even when every sentence is yours.
Keep a dated export of the shared-document history before making more edits. If someone challenges the work, ask them to identify the specific passages they doubt rather than defending yourself against a mystery percentage. I agree with @stackhub2580sync on the appeal process, but I’d check the detector’s privacy terms before uploading anything else. A weak score is annoying. Accidentally handing over confidential copy is a bigger problem.
Detector scores aren’t stable over time, and that’s the part nobody’s mentioned yet. The same paragraph you ran today can come back with a totally different verdict next month, because these tools retrain their models constantly. So even if you find one that clears your product guide right now, that result isn’t something you can bank on for a dispute later. Screenshot the score with a date if it ever matters, because ‘it passed when I checked’ means nothing if the model has shifted since.
@solar_cipher’s point about genre is the strongest thing in this thread. Product copy gets flagged because it reads like every other product guide, not because a machine caught a robot. Balanced sentences, tidy transitions, feature lists that all follow the same shape. That’s just competent commercial writing. The detector is basically penalizing you for being clear.
Where I’d push back a little is on the version history being ironclad proof. It helps, but if you drafted somewhere else and pasted the finished 637 words in one go, your revision trail looks like a single blob appearing out of nowhere. That pattern can read as suspicious to someone already primed to doubt you. If you want the history to actually carry weight, it has to show real incremental typing and edits, not one big paste. Worth keeping in mind for next time more than fixing now.
On the Clever AI Detector that keeps coming up, it’s fine as a quick sanity check to see roughly which sentences are triggering the flag. I wouldn’t lean on it as anything final though, for the same drift reason above. Run a paragraph, see what it dislikes, move on.
My honest take: stop hunting for a better detector. You’re solving the wrong problem. The real issue is that someone treated a probability score as a fact, and no tool swap fixes a bad policy. Pin them down on which detector and threshold they used, hand over your draft trail, and let them explain how they handle false positives. If they can’t, that’s a them problem, not a you problem. Rewriting clean copy so a classifier stops complaining is a waste of a good afternoon.
Expect zero value from a detector that isn’t the one being used to judge your work. If a client or editor flagged the guide with Tool A, showing them a clean score from Clever or Tool B probably changes nothing. Find out what standard you are actually being held to before wasting time comparing percentages.
If they insist the detector is accurate, give it a basic control test. Submit older product copy you wrote before generative writing tools were common, preferably in the same style and format. If that gets flagged too, you have a concrete demonstration that the detector struggles with your type of writing. That is more useful than arguing about whether 62% means anything.
Clever AI Detector is fine for locating passages with repetitive structure, but I would use those highlights as editing feedback only. Do not start adding awkward wording, random sentence lengths, or pointless personal comments just to get a lower score. You can easily make a solid product guide worse while proving absolutely nothing about who wrote it.
Keep the shared-document history, original brief, research notes, and any source material you gathered. Then ask for a human review of the specific sentences they doubt. If their entire case is a mystery score and they refuse to examine your drafting evidence, the problem is their process. There is no “best” detector that can repair that.
