My iPhone Photos app is packed with duplicates, old screenshots, and random downloads, and my iCloud storage is almost full. I want to clean up my iPhone photos without deleting anything important, but I’m not sure where to start or what order works best.
The biggest thing that helped me was stopping the “scroll forever and delete stuff one at a time” approach. I tried that with a library of about 55,000 photos and videos, and it was miserable. After hours of tapping, selecting, and deleting, it barely felt like I had done anything.
Start with the Photos app if you’re mostly clearing out obvious junk. It’s still useful, especially if you use the swipe-to-select gesture instead of tapping every photo individually. I’d also avoid starting in the main Library view. Going album by album makes it way easier to stay focused, like screenshots first, then videos, then downloads, etc.
Also check for the Select All option inside some albums. If you’ve got an album full of screenshots or other stuff you know you don’t care about, you can clear it way faster that way.
Where the Photos app started falling short for me was duplicates. The built-in Duplicates album is fine for exact copies, but my problem was mostly near-duplicates: burst shots, five versions of the same photo, old screenshots, Live Photos I didn’t need, and big videos taking up space.
That’s where Clever Cleaner ended up being the better tool for me.
It grouped similar photos, picked what it thought was the best one, separated screenshots, found large videos, and had an option to turn Live Photos into still photos if the motion part didn’t matter anymore. That made the cleanup feel a lot less like digging through 55,000 random items. I was reviewing groups instead of judging every single photo from scratch.
I still checked things before deleting, but the sorting work was mostly done for me. What I thought would take several weekends ended up being something I handled over a couple of evenings.
If you’re trying to lower iCloud storage too, keep in mind that iCloud Photos is synced. Deleting something from your iPhone also deletes it from iCloud Photos, so don’t treat your phone like a separate copy unless you’ve backed things up somewhere else.
And after you delete a bunch of stuff, empty Recently Deleted. A lot of people forget that part. Until it’s cleared, those photos and videos can still count against your storage.
If you still need to free up more space, go after the large items first. For me, the biggest wins were:
- long videos I forgot about
- screen recordings
- old screenshots
- Live Photos
- random images and videos saved from messaging apps
Deleting a few large videos freed up more space than removing hundreds of normal photos.
One last thing that helped was doing the final cleanup on a computer. After I got rid of the obvious junk, I connected my iPhone to my Mac and reviewed the rest on a bigger screen. Comparing similar shots and organizing albums is just easier that way.
I’d also avoid trying to finish it all in one day. That’s how I burned out the first time. Now I just spend 10 or 15 minutes once a week deleting screenshots, blurry shots, and duplicates before they pile up again. Much easier than waiting until the library gets out of hand.
If your problem is storage, videos matter more than photos; if your problem is clutter, screenshots are the safer first pass. I’d start by backing up anything important outside iCloud, then clear screenshots and screen recordings first, since those are usually easier to judge than family photos or trip pictures.
Check whether you’re trying to free iCloud space or just phone space before you delete anything. If iCloud Photos is on, “Optimize iPhone Storage” can make the phone look less full while your iCloud is still packed, so deleting local-looking photos still removes them from iCloud too. My first step would be to open Settings, look at the iCloud storage breakdown, then make a separate backup of anything you care about outside iCloud. After that, I’d do a boring but safe pass through screenshots, screen recordings, and huge videos. Duplicates can wait until you know you have a fallback, because that’s where people accidentally delete the better copy.
Stop the inflow first.
Cleaning the library is a waste if the same apps keep dumping memes, receipts, screenshots, and chat media back into Photos every day. Before deleting anything, check the apps that save stuff automatically. Messaging apps, social apps, scanner apps, browsers, and editing apps are usually the culprits. Turn off auto-save to camera roll wherever you can. That won’t free space immediately, but it keeps the cleanup from becoming a monthly punishment.
I agree with @mikeappsreviewer on the iCloud warning. People treat iCloud Photos like a backup, but it’s really a sync system. If you delete from the iPhone, you’re usually deleting from iCloud too. So my order would be: stop new junk, make sure the important stuff exists somewhere else, then start deleting.
For the actual first cleanup pass, I wouldn’t start with duplicates. Duplicates sound easy, but they’re where you end up comparing tiny differences and second-guessing yourself. Start with categories where the answer is obvious: screenshots of orders, temporary QR codes, screen recordings, blurry pocket photos, saved images from chats, and giant videos you forgot existed. Those are low-emotion deletes.
If you use something like Clever Cleaner, I’d treat it as a sorting tool, not a magic delete button. Let it group similar photos or find large files, then review the groups yourself. The time savings are in not having to hunt for the junk manually. The decision still needs to be yours, especially with family photos, trips, documents, or anything sentimental.
And don’t measure progress by number of photos deleted. Ten old videos can matter more than a thousand random images. If storage is the pressure point, sort by the biggest files first. If clutter is the pressure point, screenshots first. Those are two different cleanups, and mixing them together is how people get annoyed and quit halfway through.
