Accidentally Deleted Videos, Can SD Card Video Recovery Help?
I accidentally deleted important videos from my SD card while clearing space, and now I’m trying to figure out if SD card video recovery is possible. These files matter to me, and I need help finding the best recovery method or software before anything gets overwritten.
I lost a shoot once, and the first mistake I almost made was using the card again. If your video got deleted, pause everything. Those first few minutes matter more than people think.
Most of the time, deletion does not wipe the video data right away. The card usually marks the space as free and waits until new footage lands on top of it. If nothing overwrote it yet, you still have a shot.
1. Stop touching the card
Do this first, no detours:
  1. Stop recording.
  2. Do not shoot photos.
  3. Do not format the card.
  4. Pull it out of the camera.
I’ve seen recoveries fail because someone kept filming for another ten minutes, thinking one deleted clip would stay put. It didn’t.
2. See if your computer still sees the card
Put the card in a reader and connect it to your computer.
If Windows throws a format prompt or labels the card as RAW, don’t panic yet. I’ve had cards in worse shape still scan fine in recovery tools. The key thing is simple, the device needs to appear at all.
If the card does not show up anywhere, repeated unplugging and plugging back in usually goes nowhere. At that point, a recovery shop starts making more sense.
3. Start with recovery software
For deleted video files, I’d start with Disk Drill.
The reason is the Advanced Camera Recovery mode. A lot of cameras do not save long video files in one neat block. They scatter pieces of the clip across the card. So a scanner might find chunks of data but still fail to rebuild a clean, playable video.
This mode was built for stuff like that. It tries to piece fragmented recordings back together, which helps with footage from GoPro, DJI, Sony, Canon, Nikon, Fujifilm, Insta360, dashcams, and similar gear. I’ve seen fragmented files come back in one tool and stay broken in another, so this part matters.
Basic flow:
  1. Connect the card with a card reader.
  2. Open Disk Drill.
  3. Select the memory card.
  4. Pick Advanced Camera Recovery.
  5. Run the scan.
  6. Preview what turns up.
  7. Save recovered videos to another drive.
Do not restore files back onto the same card. I know it sounds obvious, but people do it.
4. Try other tools if the first pass misses stuff
No single program gets everything. I’ve had one tool miss clips and another pull half of them back.
  1. PhotoRec is free and useful, though filenames and folder layout usually come back as a mess.
  2. R-Studio goes deeper and gives you a lot of control, but the interface is kind of a slog at first.
  3. DiskGenius helps when the card has file system issues or partition damage.
Different tools scan in different ways. If scan one looks bad, scan two with another program sometimes pulls out extra files. Weird, but true.
5. Make an image of the card first if the footage matters
If the clips are important, work from a full image instead of the original card.
A byte for byte image gives you an exact copy. Then you run recovery attempts on the copy, not on the card itself. I prefer this when the footage matters or the card seems unstable. It keeps the original state intact for later tries.
6. Know when to stop doing this yourself
Software works best for logical problems like these:
  1. Deleted videos.
  2. Accidental formatting.
  3. File system corruption.
  4. RAW cards.
  5. Missing files on a card that still behaves normally.
A recovery lab is the safer move when you see stuff like this:
  1. Physical damage to the card.
  2. The card gets hot.
  3. Your computer does not detect it at all.
  4. It disconnects during scans.
  5. The footage matters enough that you don’t want to risk a bad DIY attempt.
If any of those are happening, I would stop poking at it. Extra attempts on a failing card sometiems make the next step harder.
Yes, SD card video recovery is possible if your deleted clips were not overwritten.
I agree with @mikeappsreviewer on the big rule, stop using the card. I differ on one part though. I would image the card first before throwing multiple scanners at the original, even when the card looks fine. SD cards fail in ugly ways, and repeated full scans are not risk free.
My order would be this:
  1. Lock the SD card, if it has a switch.
  2. Connect it with a decent card reader, not the camera.
  3. Create a full image file of the card.
  4. Run recovery on the image, not the card.
  5. Save recovered videos to your computer or another drive.
For deleted videos, Disk Drill is a solid first pick. Its camera-focused recovery is useful for MP4 and MOV files from cameras, drones, GoPros, and phones, esp if the clips were split or fragmented. If filenames matter less than raw recovery, PhotoRec often pulls more file data, but the output is messy as hell.
One more thing people miss. If you deleted files in the camera, some brands write new index data fast. That hurts recovery odds even if you did not record new footage. So time matters.
If the card disconnects, shows 0 bytes, or gets warm, stop. Send it to a lab.
If you want a quick explainer, this reel on SD card and memory card video recovery covers the basics well:
watch this quick SD card video recovery reel
Short version, yes, you still have a shot. Don’t write anything new to the card, don’t recover back onto it, and start with an image plus Disk Drill.
Yes, SD card video recovery is absolutely possible, but the odds depend on one boring thing nobody wants to hear: whether anything wrote new data to that card after deletion.
I mostly agree with @mikeappsreviewer and @sonhadordobosque, but I’m a little less convinced that people always need to jump between a bunch of tools right away. Sometimes that just turns recovery into chaos. If this is a straight accidental delete and the card still mounts normally, I’d start simple.
A few things people forget:
  • Check the camera’s internal app or gallery cache if the videos were viewed on a phone/tablet at any point.
  • Some cameras create proxy files, thumbnails, or low-res companion clips. Those can at least confirm what was there.
  • If the recovered video won’t play, that does not always mean it’s unrecoverable. A lot of recovered MP4/MOV files just need repair because the metadata header is messed up.
For actual recovery, Disk Drill makes sense here because video files from SD cards are often fragmented, esp from action cams and drones. I’d scan, preview what it finds, and recover to a computer drive, not back to the card. If you get files back but they are corrupted, then look at video repair as step two, not step one.
Also, tiny disagree with the “keep trying lots of scans” approach. On a flaky SD card, more scans can be a bad idea fast. If the card starts acting weird, stop messing with it.
If you want more real advice on recovering deleted videos from an SD card, that thread is worth reading too.
Short version: yes, recovery is possible, and if the card hasn’t been reused, your chances are pretty decent.
