I’ve been using the free version of AI Cleaner for a while and I’m unsure if upgrading to premium is really worth the cost. I’ve seen mixed reviews online and don’t want to waste money if the extra features don’t make a noticeable difference in speed, malware detection, or overall system cleanup. Can anyone share real experiences or detailed reviews of the premium version and whether it genuinely helped their PC performance?
AI Cleaner: Clean UP Storage – my experience vs a better option
AI Cleaner: Clean UP Storage App Review
I installed AI Cleaner: Clean UP Storage when my iPhone was down to single digit free space and Photos app was taking ages to load.
First run looked decent. It did a full scan, showed a nice colorful breakdown of “junk”, “duplicates”, “similar photos” and so on. Then the catch started.
Every time I tapped on something useful, there was a “go premium” screen. I tried to remove a batch of videos, got asked to upgrade. Tried to clear more than a small amount of “junk”, upgrade again. It felt like a demo, not an app.
The “AI” grouping of duplicates was off for me. It put together slightly similar shots of my kid that I wanted to keep, and sometimes missed actual duplicates from WhatsApp vs Camera Roll. I had to double check everything, which killed any time savings.
Real user reviews look similar to what I saw:
After 15 minutes of fighting paywalls, I deleted it and went hunting for something else.
What I switched to: Clever Cleaner
Then I tried this one:
Clever Cleaner on App Store
Different story.
No subscription popups, no fake “free” scan that turns into a paywall. I could use the features without getting hammered by upsells or full-screen ads.
What it helped me remove
On my first run with Clever Cleaner it found:
• Duplicate and nearly identical photos
• Old screenshots I forgot about
• Large video files and other space hogs
A couple of concrete numbers from my phone:
• Around 1.8 GB from useless screenshots and screen recordings
• Around 3.2 GB from duplicate and similar photos
• A handful of big videos from years ago that I never watch
The “similar photos” grouping seemed more precise than AI Cleaner. It grouped burst shots and slightly moved copies together in a way that made sense. I still skimmed before deleting, but I did not feel like I was fighting the app.
Privacy part
The main thing I checked: where the analysis happens.
Clever Cleaner runs on-device. It does the photo analysis locally, so your images are not sent to a server for processing. For me that matters, because I do not want some random cleanup app to hold copies of my photos on their backend.
With AI Cleaner, I did not get a clear sense of what was processed where. I did not see anything horrible, but the privacy story was not as explicit, and with photo access involved I prefer clear wording.
How it felt to use, day to day
AI Cleaner
• Constant upgrade prompts when trying to perform useful actions
• Limited free usage, felt like a teaser instead of a tool
• Inconsistent duplicate detection, so I had to carefully check each suggestion
• Left me slightly nervous about deleting anything in batches
Clever Cleaner
• No aggressive paywalls or forced plans
• Fast scans, even on a photo library with over 20k items
• Reasonable groupings for similar photos and duplicates
• Local-only processing, better for privacy and offline use
• I finished a full cleanup session in under 10 minutes
If you are drowning in photos and random files, I would start with Clever Cleaner instead of AI Cleaner. It wasted less of my time and did not try to upsell me on every tap.
Extra links if you want to check it yourself
YouTube walkthrough
Clever Cleaner homepage
Get Clever Cleaner on the App Store
There is also a good Reddit thread that compares iPhone cleaner apps and explains why some of the “miracle” ones are risky or useless:
Best cleaner apps on Reddit > https://www.reddit.com/r/DataRecoveryHelp/comments/1d733gm/best_iphone_cleaner_apps_and_why_you_shouldnt_use/
Short answer from my side, no, upgrading AI Cleaner to premium does not seem worth it for most people.
A few points based on what you wrote and what @mikeappsreviewer shared:
What premium actually gives you
On these cleaner apps, premium usually means:
• Unlimited bulk deletes
• Full “similar photos” cleanup
• Video and large file filters
• Sometimes “faster” AI or priority supportThe free tier often shows you the junk, then blocks you when you try to delete most of it. So you end up paying to remove data you could remove manually in Photos and Settings.
Where AI Cleaner falls short
My own test on AI Cleaner looked close to what others reported.
• Aggressive paywalls once you start doing anything useful.
• “Similar” photos groups were mixed. Good in some cases, bad in others.
• Needed manual checking on each batch, or you risk losing stuff you want to keep.If you still have to double check every group, the “AI” is not saving you much time. That makes the subscription harder to justify.
When premium might be worth it
I would only consider AI Cleaner premium if:
• Your library is huge, like 30k+ photos.
• You are short on time and okay paying for some automation.
• You test it during a short trial and see at least a few GB safely reclaimed.If a quick run does not find obvious junk or duplicates that you agree with, premium will not magically get better.
What to do before spending money
Do this first:
• Use iOS “Recommendations” under Settings > General > iPhone Storage. It often suggests big attachments, old conversations, and offloadable apps.
• In Photos, sort by “Screenshots” and delete old ones.
• Sort by “Videos” and remove long clips you do not need.Many people clear 5 to 10 GB this way, without any app.
Alternative that tends to work better
Since you are already comparing, the Clever Cleaner App is worth a look.
Key points from my own run:
• Analysis runs on-device, so your photos stay on your phone.
• Similar photo grouping was more precise for me. It handled bursts and near-duplicates with fewer weird matches.
• Less nagging about subscriptions compared to AI Cleaner.I am not saying it is perfect, and I do disagree a bit with the idea that AI Cleaner is totally useless. Some people will value its interface. But if you are cost sensitive and worried about wasting money, Clever Cleaner App and the built-in iOS tools give you more value per minute.
Practical test to decide
Before you upgrade AI Cleaner, do this small check:
• Run a full scan with the free version.
• Manually count how many photos and videos it flags that you would genuinely delete.
• Estimate the storage it says you will save.
• Ask yourself if you would pay that subscription price today for that amount of saved space.If you hesitate, skip premium. Try Clever Cleaner App or stick to manual cleanup and iPhone Storage recommendations.
Short version: for most people, AI Cleaner Premium is not worth paying for, especially if the free version already feels annoying or limited on your phone.
A few extra angles that @mikeappsreviewer and @vrijheidsvogel didn’t really cover:
Look at how it’s charging you
AI Cleaner loves subscriptions. That’s fine for something you use weekly, but a storage cleaner is usually “use hard for 1–2 days, then forget about it.”
Paying every week/month for an app you only need during occasional cleanups is… not great value. If they offered a cheap one‑time unlock, I’d feel very different about it. -
Premium does not fix the core problem
You mentioned mixed reviews. A lot of those complaints are about:
- Inaccurate “similar” photo groups
- Needing to manually review everything
- Fear of deleting important stuff
A subscription does not magically improve the AI quality. If the free version is already misgrouping your photos, premium mainly removes limits, not mistakes. You just get to make bigger mistakes faster.
- Test how much trust you have in it
Before paying, do this quick sanity test in the free version:
- Open a few “similar” groups and ask: would I hit “delete all” here without thinking?
If the honest answer is “no, I don’t trust it,” then premium is a bad idea. A cleaner app you do not trust defeats its whole purpose, no matter how many GB it claims it can free.
- Where I slightly disagree with others
Both @mikeappsreviewer and @vrijheidsvogel are pretty down on AI Cleaner. I’m a bit less harsh: the UI is not terrible, and if someone has zero patience for manual sorting, it can be a shortcut.
But that only matters if:
- You accept a subscription model
- You are willing to keep an eagle eye on every batch delete
If either of those annoy you already, AI Cleaner Premium will just annoy you faster.
- Compare the “time-to-value” with alternatives
This is where the Clever Cleaner App actually makes sense as a comparison:
- You spend less time fighting paywalls
- The on-device analysis is more transparent privacywise
- Similar photo grouping tends to need less babysitting
Even if you ignore the privacy thing, the simple fact that you can get through a cleanup session quicker and with fewer “are you kidding me?” subscription popups makes it the more practical option in real life.
- My bottom line for your exact situation
Given you:
- Already used AI Cleaner free for “a while”
- Are hesitant because of cost and reviews
- Do not want to waste money
That combination screams “do not subscribe to this one.” If you were in love with how it scans and organizes things, you would not be here asking.
I’d:
- Use the builtin iPhone Storage tools to clear the obvious junk.
- Try Clever Cleaner App for a proper automated pass, since it’s less aggressive about paywalls and runs local analysis.
- Only circle back to AI Cleaner Premium if you somehow find its interface dramatically better during a free trial and you are ok with a sub.
If your gut says “this feels like a teaser and kind of scammy,” trust that. The app experience never gets less pushy after you put your card in.
Skip AI Cleaner Premium. A recurring fee makes little sense if you clean storage once every few months. Premium removes limits, but it does not improve weak photo grouping or reduce manual review.
A simpler option is moving old photos and videos to a computer or external SSD. Import everything older than one year, verify the files open, then delete those items from your iPhone and empty Recently Deleted. Large videos free alot of space fast, with no subscription or risky AI sorting.
Watch the auto-renew before you even think about premium. Most of these cleaners hook you with a ‘3 day trial’ that quietly rolls into a full subscription, and the cancel flow is buried on purpose. If you do test AI Cleaner premium through a trial, set a reminder and kill it in your Apple subscriptions the same day, otherwise you’re paying for something you touched once.
The thing nobody in here has flagged: deleting photos through any of these apps doesn’t actually free space right away. Everything you remove lands in Recently Deleted and sits there for 30 days, still counting against your storage. So people run a big cleanup, check their free space, see barely any change, and assume the app scammed them. It didn’t lie exactly, you just have to go empty that folder yourself. Worth knowing before you judge whether free or premium ‘worked.’
I mostly agree with @techchizkid that premium removes limits, not mistakes. That’s the real problem. Paying more so you can batch-delete faster with an AI that already misgrouped your kid’s photos is how you lose stuff you wanted. Bigger delete button, same bad grouping.
Clever Cleaner keeps coming up and I get why, the on-device angle and no paywall spam make it a saner first pass than AI Cleaner. I wouldn’t oversell it though. It’s still a review-before-you-delete tool, not something you trust blindly. Use it to surface the obvious duplicates and old screenshots, then eyeball the groups yourself.
Honestly for your situation, the answer is skip premium. You’ve used the free version ‘a while’ and you’re still hesitant, that’s your gut telling you it isn’t clicking. Clear the low-hanging junk with the built-in iPhone Storage tool, run one free scan with something less pushy, empty Recently Deleted, and see where your storage lands. If that’s enough, you never needed a subscription in the first place.
