I accidentally deleted my favorite reading app from my phone, and I can’t remember the name. I need a good reading app to find new books and keep track of my progress. Any suggestions for the best reading apps out there?
Hey, losing your favorite app can be such a pain! No worries, though—there are plenty of great reading apps out there that can help you discover new books and track your reading progress seamlessly.
If you’re looking for robust recommendations, Goodreads is often the go-to. It has a massive community of readers, so you can find reviews and suggestions tailored to your tastes. Plus, it lets you create “shelves” to keep track of books you’ve read, are currently reading, or want to read.
Another option worth checking out is Libby. It connects you to your local library’s collection of ebooks and audiobooks, allowing you to discover titles you might not have considered otherwise. You can also place holds and manage your loans directly through the app.
For a more personalized recommendation engine, try Bookly. It’s great for setting reading goals and tracking your progress with detailed statistics. It offers suggestions based on your reading history and preferences.
For those who prefer minimalist design and straightforward functionality, Readtracker is a solid choice. It lets you log your reading sessions and track your progress through books in a simple, clutter-free interface.
If you can’t remember the specific app you used before, these alternatives should definitely get you back on track. Happy reading!
Yes, losing your fav app is pretty annoying! On top of the solid suggestions already mentioned, you might also want to check out Litsy. It’s a bit like Instagram but for books—perfect if you love sharing your reading journey through pictures and posts. Plus, it can help you discover new reads based on the trending recommendations from fellow book enthusiasts.
Another cool app to consider is StoryGraph. It provides very insightful reading stats and personalized book recommendations that are based on a mood-metric system. It’s a bit more data-driven compared to Goodreads which could be refreshing if you’re into stats and detailed analyses.
If you need something specifically for tracking and structuring your reads, Basmo is worth a shot. It’s designed to help you set daily reading goals, create to-read lists, and keep all your reading notes in one place. It steers a bit away from the social aspect and focuses more on your individual reading habits.
Also, if the lost app had a strong community feature, then you might find BookSloth quite handy. It’s designed to give personalized book recommendations and allows you to join book clubs online.
Finally, don’t forget about Scribd. Although it’s technically more of a subscription service for ebooks and audiobooks, its library is huge and constantly updated. Plus, it has excellent tools for tracking your reading progress and even offers some curated recommendations.
Good luck finding your next favorite app! ![]()
Try using your reading history to rebuild what you lost.
Open your ebook stores, like Kindle, Google Play Books, Apple Books. Check your purchase and sample history.
Open your email. Search for “your reading goal,” “finished reading,” “weekly book,” “reading stats,” “TBR,” “club.” Many apps send summary mails.
Check your phone’s app store history. Search for “books,” “reading,” “tracker.”
Screenshot any app icons that look familiar, then compare in the store.
This helps you restore your old setup instead of switching to a new system.
