Can someone explain what an FTP client actually does
I keep seeing people recommend using an FTP client to upload and manage website files on a server, but I’m still not clear on what it actually is, how it works, or why I’d use it instead of just my web host’s file manager. I’m trying to set up a small site and don’t want to mess anything up. Can someone break down what an FTP client is, what it’s used for, and which basic features I should look for when choosing one?
An FTP client is basically that middleman app that shuttles files between your computer and some machine sitting out there on the internet (usually called an FTP server). It is not magic, it is just a specialized tool that speaks a specific protocol so both sides understand what is going on.
How it differs from your regular browser
When you hit a normal website, your browser is the client. It sends a request, gets some HTML, images, scripts, then renders all that into a page. You mostly just read or click.
An FTP client is a bit more blunt: no pretty pages, no styling, just files and folders. You connect, you see a directory listing on the remote side, and you push or pull files directly. It is built for two-way transfer, not for viewing.
Where it actually shows up in real life
Typical example: you are putting together a website.
  • You build your pages, images, and scripts locally.
  • Then you use an FTP client to upload all that to your hosting provider’s server so the world can see it.
  • Later, if you want a backup, you open the same client and yank everything back from the server to your machine.
That is the loop: edit locally, upload to server, download backups when you are paranoid or things break.
Same idea if you are managing logs on a remote machine, trading large files with a client who has their own server, or digging around in old-school web hosting where there is no fancy deployment system.
Tools people actually use
On macOS, a lot of folks end up looking for something that is not clunky or ancient. One app I have seen used in that space is Commander One:
https://apps.apple.com/us/app/commander-one-file-manager/id1035236694?mt=12
The main draw is the dual-pane file manager layout: local files on one side, remote stuff on the other, drag and drop between them. That makes it feel more like managing two folders than “doing FTP.” On top of plain FTP, it also handles things like SFTP and connections to cloud services, so you are not stuck with just one type of server. That matters if you care about security or are mixing traditional servers with newer storage.
If you do not need extra bells and whistles and just want something that works across different operating systems, there is also FileZilla. It is the kind of tool you install once and then forget about, because it just sits there doing basic FTP/SFTP transfers without drama. Not pretty, not fancy, but if your needs are “connect, upload, download, done,” it covers that fine.
In short, an FTP client is the workhorse that moves your files to and from a remote machine. The rest is just picking the one that matches how much you care about interface, security, and extra features.
Think of it like this: your web host’s file manager is a tiny toolbox bolted to the wall in a cramped closet. An FTP client is you driving a moving truck straight into the warehouse.
What an FTP client actually does
  • Talks to a remote server using the FTP/SFTP protocol
  • Shows you your local files and the server’s files
  • Lets you upload, download, rename, move, delete, change permissions
  • Handles big batches of files, queues, and reconnects when things glitch
Why not just use the host’s file manager?
  • Browser file managers are usually slow, buggy, and limited to small uploads
  • If your internet hiccups during a big upload, the browser often just fails
  • Editing a lot of files is painful one‑by‑one in a web UI
  • No convenient sync, no drag and drop between folders, no real queueing
With an FTP client, you can:
  • Upload an entire site folder (hundreds of files) in one go
  • Reconnect quickly if your login times out
  • Compare timestamps and overwrite only changed files
  • Pull a full copy of the site for backup in one operation
I’d slightly disagree with @mikeappsreviewer on one thing: it can feel like “doing FTP” when you first start, because you have to deal with host, port, username, password, maybe a private key, and sometimes weird passive/active mode issues. Once that’s set up though, it really does become “just managing two folders.”
Security bit that often gets skipped
Avoid plain FTP if you can. Use SFTP (FTP over SSH) or FTPS. Many hosts disable old FTP entirely for security. If your panel only shows “FTP details,” check if SFTP uses the same credentials and port 22.
Why people keep recommending FTP clients
  • They’re faster and more reliable for real work
  • They’re not tied to a specific host’s panel, so you can use the same tool for multiple servers
  • You keep everything on your machine, edit with your own editor, then upload
Mac‑specific note
If you’re on macOS and prefer something that feels like a normal file manager instead of a “nerdy FTP box,” Commander One is actually nice: dual panes, local on one side, server on the other, drag and drop, supports FTP/SFTP and some cloud stuff. It’s less “I am now doing server operations” and more “I’m just moving files around.”
So in plain terms: an FTP client is your remote file explorer, built for talking to servers. The web host’s file manager is fine for quick one‑off fixes; for anything beyond that, you’ll want the moving truck, not the bucket.
Think of an FTP client as “remote Finder / File Explorer for your server,” not some mystical dev tool.
Your host’s file manager is like trying to move an apartment’s worth of furniture using the trunk of a tiny car. Technically works, super annoying. An FTP client is the moving van.
What it actually does, in practice:
  • Connects from your computer to a remote machine (your web server) using FTP, SFTP, or FTPS
  • Shows two file trees:
    • Left: your local files
    • Right: the server’s files
  • Lets you:
    • Upload/download files and folders
    • Rename, move, delete stuff on the server
    • Change permissions (chmod)
    • Queue big batches so you can upload a whole site in one go
Where I slightly disagree with @mikeappsreviewer and @cacadordeestrelas is on the “it’s just a middleman, no big deal” vibe. For small, one‑off edits, the web host file manager is actually fine. Like, if you just need to tweak a single config file once a month, firing up an FTP client can feel like overkill.
But the moment you:
  • Have a lot of files (themes, plugins, images, assets)
  • Need to sync changes regularly
  • Want a full backup of your site
  • Need to recover from “I broke everything in production”
then an FTP client goes from “optional” to “how did I ever live without this.”
Security bit: plain old FTP sends logins in clear text. That’s… not great. Use SFTP if your host offers it. Same general idea, just over SSH and encrypted. Most decent FTP clients handle this without making you think about it much.
Why people keep telling you to use an FTP client instead of only the web file manager:
  • Browser uploads often choke on big folders or flaky connections
  • No real queueing or resume for long transfers in most control panels
  • Editing a whole theme or app via a web interface is pain personified
  • FTP clients let you keep your workflow local (use VS Code or whatever), then just push changes
On macOS specifically, Commander One is actually worth a look. Compared to something like FileZilla, it feels more like a “normal” dual‑pane file manager and less like a 2003 utility that refuses to die. Local files on one side, server on the other, drag and drop. It also supports SFTP, which solves the “don’t use plain FTP” issue without extra drama.
TL;DR: An FTP client is not some dev-only wizard tool. It’s just a specialized file manager that talks to servers, makes uploads and backups sane, and saves you from wrestling with clunky web panels every time you touch your site.
