I’m having trouble with Dropbox error 8737.idj.029.22 and can’t access or sync some of my files. It started suddenly, and basic troubleshooting hasn’t fixed it. I need help figuring out what this error means and how to fix it so I can get back to my documents.
8737.idj.029.22 does not look like a standard public Dropbox error code. When Dropbox throws odd mixed codes like this, the cause is often one of 4 things. Corrupted local cache, a stuck sync database, a blocked file path, or security software blocking Dropbox.
Try this in order.
Check Dropbox Status page.
If sync services are down, wait. Rare, but it happens. -
Pause Dropbox, then quit it fully.
On Windows, end Dropbox.exe in Task Manager.
On Mac, quit from Activity Monitor if needed.
Then reopen it. -
Look for bad file names.
Dropbox often fails on:
Files with trailing spaces.
Names with reserved characters.
Paths over about 260 chars on older Windows setups.
Temp files from Office or Adobe.
Try moving one affected file to a short path like C:\Test. -
Check disk space.
Dropbox needs free local space for sync and indexing. If your drive is near full, sync errors show up fast. -
Clear the local Dropbox cache.
Open your Dropbox folder.
Find .dropbox.cache.
Delete its contents, not your real files.
This fixes a lot of weird sync bugs. -
Relink the app.
Sign out of Dropbox in Preferences.
Sign back in.
If needed, unlink and relink the device from your account page. -
Disable antivirus or firewall for 5 minutes.
A lot of third-party AV tools block Dropbox writes. Seen this with Bitdefender, Avast, and some corporate endpoint tools. Re-enable after testing. -
Check permissions.
Make sure your user account owns the Dropbox folder and has read/write access. On Windows, right-click folder, Properties, Security. On Mac, Get Info, Sharing & Permissions. -
Use selective sync.
If only some folders fail, unsync them, let Dropbox settle, then resync. Crude, but it works more often than it should. -
Reinstall Dropbox cleanly.
Uninstall it.
Delete leftover Dropbox app data.
Reinstall the latest build.
Do not delete your cloud files. The local index gets rebuilt, which fixes db corruption a lot of the time.
If none of this helps, post 3 details.
Your OS and version.
Whether web access to those files still works.
Whether the problem hits all files or only a few.
Also check the Dropbox logs folder. There’s usuallly a clue in there.
8737.idj.029.22 honestly looks less like a real Dropbox code and more like an internal app/log identifier that bubbled up to the UI. So I’d stop chasing the exact code and try to figure out where the failure is happening.
A couple things I’d check that @nachtschatten didn’t really get into:
- Test Dropbox on the web with the same files. If they open fine there, your cloud copy is probably okay and the issue is local app/database/OS related.
- Check if the affected files are online-only, locked by another app, or sitting in a folder that got moved by OneDrive/iCloud/Desktop/Documents backup stuff. That cross-sync conflict causes weird errors all the time.
- If you’re on Windows, look in Event Viewer around the time the error started. On Mac, Console. You may see filesystem or permission errors Dropbox itself hides.
- See whether the files are actually blocked by Windows. Right click file, Properties, and look for an “Unblock” checkbox.
- Run a disk check. Not glamorous, but sudden sync weirdness can come from file system errors.
- Windows:
chkdsk /f - Mac: Disk Utility > First Aid
- Windows:
One place I kinda disagree with @nachtschatten: jumping to reinstall too early can waste time if the real problem is a bad drive, account restriction, or another sync service interfering.
Also worth checking:
- Dropbox account storage full
- File ownership changed after OS update
- VPN/proxy/filtering DNS breaking API calls
- Team/business admin restrictions if this is a work account
If you can, post:
- Windows or macOS version
- Dropbox app version
- Whether web access still works
- Exact behavior: “can’t open,” “won’t sync,” or “shows missing”
That’ll narrow it down prety fast.
That code smells like a corrupted local Dropbox index more than a true “file is gone” problem. I slightly disagree with @nachtschatten on one point though: Event Viewer and disk checks are useful, but before digging into OS logs, I’d test whether Dropbox is failing only on one path type.
Try this:
- Create a brand new folder at the root of Dropbox.
- Put in one tiny test file like a .txt.
- Rename it with a very short name.
- See if that syncs.
Why this matters:
- If new files sync, but old ones do not, the issue is often path length, invalid characters, or a stuck namespace.
- If nothing syncs, it is more likely the local Dropbox client state is broken.
Things not mentioned yet that are worth checking:
- File path too long on Windows
- Reserved characters in filenames:
* ? < > : | - Case-only renames from Mac to Windows causing sync stalls
- Selective Sync accidentally removing the folder locally
- Extended attributes or package-style folders on macOS confusing Dropbox
- Antivirus quarantining Dropbox temp files
A good next move is a Dropbox app reset, not a full reinstall. Reinstalling sometimes preserves the same bad cache. Resetting forces a cleaner rebuild of metadata.
Pros for ‘’:
- Can improve readability if you are documenting the issue
- May help organize troubleshooting notes
Cons for ‘’:
- Not relevant unless you are tracking lots of test results
- Won’t fix the sync bug itself
Also check the Dropbox sync icons carefully. “Syncing,” “offline,” and “available online” get mixed up a lot and point to very different causes. If you can say whether the files fail on rename, open, move, or upload, that will narrow it down fast.
I wouldn’t assume a corrupted index from the code alone. Try the Dropbox website first for a simpler workaround.
Sign in through your browser, find an affected file, and select Download. Save it outside your Dropbox folder, then check whether it opens. Dropbox supports downloading files directly through its website.
Keep your local originals untill you compare versions. This approach restores access to downloadable cloud copies, rather than fixing desktop sync. Upload urgent edits through the website using a seperate filename to avoid replacing your existing copy.
Screenshot the exact spot where that code shows up before you do anything else. Where it appears tells you more than the code itself. If it popped out of the Dropbox desktop app or the error window inside the client, fine, treat it as a real sync fault and work through the local fixes people listed. But if you hit this code after clicking a search result, an email link, or a page that told you to ‘call Dropbox support,’ slow down. Codes shaped like this, long mixed strings nobody can decode, are a classic lure on fake support sites. Dropbox does not hand you a phone number to fix a sync error.
So first question I’d answer for yourself: did this code come from Dropbox, or from something pretending to be Dropbox?
Assuming it’s genuine, I’ll back @sterrenkijker on the test-file approach over jumping to a reinstall. A clean one line txt at the root tells you in thirty seconds whether the client is broken everywhere or choking on specific files. That’s cheap information. Reinstalling first means you might sit through a full re-index only to learn nothing.
Where I’d gently disagree with the pile of local fixes: everyone is assuming this is your drive, your cache, your permissions. If this is a work or school account, none of that may matter. Admins can throttle sync, block file types, or flag a device, and the client will spit out an unhelpful code instead of saying ‘your admin blocked this.’ If that’s your situation, stop troubleshooting the machine and message whoever runs your Dropbox team. You can burn an afternoon clearing caches on a problem that lives on someone else’s dashboard.
One small thing nobody flagged: if your files sit in a folder that’s also being grabbed by OneDrive or iCloud Desktop sync, two services fighting over the same path will throw errors that look exactly like a Dropbox fault. Check that before you blame Dropbox at all.
