Can you help me with an honest Notion app review?
I’ve been using the Notion app for personal projects and team collaboration, but I’m not sure if I’m taking full advantage of its features or if there are better alternatives for productivity and knowledge management. I’d really appreciate detailed feedback, pros and cons, and real user experiences to help me decide whether to fully commit to Notion or switch to another tool.
Short honest take after years of using Notion for myself and small teams:
What Notion does well
  1. Central hub.
    You get docs, wiki, tasks, databases, and light CRM in one place.
    For personal stuff, it works well for:
    • Project dashboards
    • Reading lists
    • Habit or workout logs
    • Journal + notes
For teams, it works as:
• Lightweight wiki
• Meeting notes linked to projects
• Simple task boards
  1. Linked databases.
    This is the real “power feature”.
    Examples that help a lot:
    • One master Tasks database, then create filtered views per person, per project, per week.
    • A Notes database linked to Projects. Each note gets tied to a project, so you see all related notes on the project page.
    • Content calendar: one database with views for Calendar, Kanban, “This Week”, “Needs Review”.
If you are not using:
• Relations
• Rollups
• Filters + sorts + views
you are missing most of the value.
  1. Templates.
    Set up templates for:
    • Meeting notes (agenda, decisions, action items)
    • Project pages (goal, scope, timeline, status, risks)
    • Repetitive tasks (checklists)
    This cuts a lot of friction.
Where it falls short
  1. Speed.
    On weaker machines or big workspaces it feels slow.
    If you need fast note capture, Obsidian, Logseq, or plain text feel better.
  2. Offline.
    Offline support is still flaky.
    For travel or unstable internet, Notion is not great as your only tool.
  3. Heavy task management.
    If your team needs:
    • Advanced dependencies
    • Workload planning
    • Gantt charts
    • Strong notifications
    tools like ClickUp, Jira, Linear, or Asana do better.
  4. Knowledge management depth.
    Notion is flexible, but if you care about:
    • Local files
    • Plain text
    • Advanced graph view
    Obsidian or Logseq feel stronger.
    They also handle long term knowledge growth better with backlinks and plugins.
How to check if you use Notion well
Ask yourself:
• Do you have one “home” page with links to your key areas?
• Do you have one master Tasks database linked to projects, instead of random checklists everywhere?
• Are you reusing templates instead of building pages from zero?
• Are you using relations between Tasks, Projects, Notes?
If the answer is no on most of those, you are leaving value on the table.
Simple setup idea for you
Personal:
• Home
  • Today view (linked tasks filtered by due date)
  • This Week view
  • Quick capture page
    • Databases: Tasks, Projects, Notes, Reading List, Habits
Team:
• Company home
  • Announcements page
  • How we work (processes)
  • Team directory
    • Databases: Projects, Tasks, Meetings, Docs / Specs
Link Tasks to Projects.
Link Meeting notes to Projects and People.
Use properties like Status, Owner, Due date, Priority.
When to consider alternatives
Look at:
• You do more coding and need markdown, git, offline: try Obsidian.
• You run sprints and complex projects: try Linear or Jira.
• You want email and docs tightly tied: Google Docs + Tasks + Drive.
• You prefer visual whiteboards: Miro or FigJam with a separate wiki (Confluence, Notion, etc).
My rough rule:
• Personal and small team wiki and light PM: Notion is great.
• Heavy engineering or big org PM: pair Notion with a real PM tool or skip it.
If you share a bit on how your team works day to day, people here can point you to a more specific setup or if you should jump to something else.
I mostly agree with @sonhadordobosque, but I think they’re actually being a bit too kind to Notion in a couple areas.
Where Notion secretly shines (if you lean into it)
  • It’s great for process, not just storage. If your team has recurring workflows (content production, client onboarding, sprint rituals), building those as database-driven pipelines with a few key properties can replace 3 other tools.
  • The real killer feature imo is structured mess: you can start as a chaotic doc, then later turn that chaos into a database, add properties, connect it to other stuff, and not lose what you already wrote. Tools like Obsidian or plain markdown are nicer to write in, but worse when you want to turn freeform stuff into semi-formal workflows.
Where I disagree a bit
  • Knowledge management depth: Notion can actually be very solid here if you design it like a graph, not like folders. Use:
    • One central “Library” database for all long‑form notes
    • Aggressive use of Relations to link ideas, projects, and people
    • Auto-generated “related notes” views
      It’s not as nerdy as Obsidian, but for non-technical teams, a well-structured Notion beats a badly-structured markdown vault by miles.
  • Task management: for small teams doing Kanban or light sprints, Notion is “good enough” if you:
    • Make one Tasks DB for everything
    • Define clear conventions (Status, Owner, Due Date, Project, Type)
    • Keep the number of views low and opinionated (Today, This Week, Backlog, Blocked)
      The problem is usually governance, not features. If everyone just makes their own boards, it collapses into chaos.
Where it really sucks (and people underestimate this)
  • Permissions at scale. Once you get past like 15–20 people, managing who can see what is painful. You either overshare or spend half your life tweaking access. Confluence or Google Drive are less “fun” but saner for access control in bigger orgs.
  • “Truth of record.” Notion makes it too easy to duplicate info. Policies, specs, OKRs, all end up with three versions and no one knows which is real. This is less of a problem in tools that are more rigid or more file-based.
How to know if Notion is right for you vs alternatives
Ask yourself these, based on how you actually work:
  1. Do you mostly:
    • Capture quick thoughts, code snippets, offline notes, heavy markdown?
      → Obsidian / Logseq feel better.
    • Run structured projects with team visibility and shared docs?
      → Notion or a wiki + PM tool.
  2. Is your team more:
    • Async, doc-driven, likes to read and write?
      → Notion works well as the central brain.
    • Meeting-heavy, chat-heavy, lives in Slack/Teams and email?
      → You might get more from Google Docs + Drive + a robust PM tool, and use Notion only as a nice wiki on top.
  3. Are you personally:
    • The kind of person who enjoys tinkering with systems?
      → You’ll probably get huge value from learning Relations, Rollups, and solid templates in Notion.
    • The kind of person who just wants to type and forget?
      → A simpler notes app plus a proper task manager is probably less overhead.
Concrete “am I underusing it?” checks that are different from what was already said
If most of these are “no,” you’re leaving value on the table:
  • Do you have one canonical place where “source of truth” lives for:
    • Current objectives
    • Active projects
    • Team processes
      …or is it scattered in random pages?
  • Are you using properties to drive behavior, not just to decorate? For example:
    • A “Status” property that actually changes which view a page shows up in
    • A “Review date” property that feeds a “Things I should revisit this week” view
    • A “Owner” property that filters each person’s personalized dashboard
  • Do you have clear rules like:
    • “Meeting decisions must be captured in the related project page, not just in the meeting note”
    • “Every project must have a linked Tasks view filtered to that project”
      Notion works best when you treat it like a tiny internal product with rules, not a dumping ground.
When I’d say: stop forcing Notion and switch / complement
  • You do heavy engineering planning, lots of dependencies, and need serious reporting → Use Jira / Linear / ClickUp for tasks, and let Notion just be the wiki.
  • You write long, complex docs with lots of comments and legal / external stakeholders → Google Docs or Word Online is less “sexy” but way more practical.
  • You are obsessed with long-term personal knowledge, backlinks, and local-first → Obsidian as your brain, Notion for “shareable” docs.
TL;DR-ish verdict
  • Personal + small team collaboration: Notion is still one of the best “all in one-ish” options if you’re willing to design a system, not just make pretty pages.
  • Big orgs, strict workflows, or power-user devs: use Notion as a layer (wiki, light hub), not as the spine of everything.
If you share how you currently use it (screenshots of your sidebar / top 3 pages, or quick description), people can usually spot 2–3 structural changes that either unlock Notion’s value for you or prove that you’re better off moving to more specialized tools.
Notion is polarizing because it tries to be everything. You’re not wrong to wonder if you’re missing something.
Where I mildly disagree with @sonhadordobosque’s angle is that they lean hard on “design a system and it becomes great.” That is true, but only if you want to be the systems person. If you feel guilty every time you open Notion because you “should” be building relations, rollups and dashboards, that’s a smell: the tool is starting to manage you, not the other way around.
A different way to evaluate your current Notion setup:
1. Look at your friction points, not just your features
Ask yourself, very concretely, in the last 2 weeks:
  • When did Notion slow you down?
  • When did you avoid opening it and default to a quick doc, sticky note, or task app?
  • When did someone say “where is that again?” about something that “lives in Notion”?
If those moments are mostly:
  • “Searching and not finding”
  • “Too many slightly similar pages”
  • “Pages that feel heavy to load for quick capture”
then you’re hitting Notion’s weak spots: sluggish capture and duplication creep.
2. You might be over‑collaborating, under‑deciding
Notion encourages collaboration but is bad at showing a clear decision log. A pattern I see:
  • Meeting notes exist
  • Project pages exist
  • But decisions live in comments, bullets, or random callouts
Instead of more databases, try one simple habit:
  • Each project page has a short “Decisions” section at the top
  • Every meeting that produces a real change updates that list, not just the meeting note
If you do only that, your use of Notion becomes more “truth of record” and less “pretty graveyard.”
3. Check whether your sidebar tells a coherent story
Without touching anything, open your sidebar and ask:
  • Do the top 6–8 visible items roughly map to how work actually flows for you or your team?
  • Or are they half old templates, half abandoned experiments?
You don’t need complex architecture. You need 4 to 8 stable “anchors,” like:
  • Inbox / scratchpad
  • Active projects
  • Tasks
  • Knowledge / library
  • Team / rituals
If your sidebar does not mirror your real mental model of work, you will always feel like you are “not using Notion right,” because the tool’s map does not match your territory.
4. Where Notion is secretly overkill
You might be happier partially “downsizing” without fully migrating:
  • Personal quick capture: a fast notes app (Apple Notes, Google Keep, whatever) for raw capture, then only promote what matters into Notion
  • Personal tasks: if your day is mostly “do 10 small things,” a dedicated task manager can feel way less heavy than a database view
  • Long commentary reviews: anything needing rich suggestion workflows or legal review fits better in Google Docs or Word, and you can just link it from Notion
In that hybrid setup, Notion becomes your curated home for things that deserve structure, not a dumping ground.
5. Pros & cons of keeping Notion as your main hub
  • Flexible enough to host projects, knowledge, and lightweight processes together
  • Good for teams that are comfortable reading structured pages instead of living in chat
  • Databases can replace a bunch of smaller tools if someone is willing to curate them
  • Visual customization can make “home pages” and dashboards feel intuitive to non‑technical teammates
  • Capture is slower than a plain text or markdown‑centric app
  • Needs active gardening, or entropy makes everything feel messy in a few months
  • Permissioning and “which version is real” problems grow quickly with more people
  • Offline / mobile experience still feels clunky for serious work
6. Quick self‑diagnosis to decide “double down vs. diversify”
Lean into Notion as your main workspace if:
  • You like periodically redesigning your system and you actually enjoy that tinkering
  • Your team is happy living in pages and databases, and they already open Notion daily
  • You can name one person who “owns” the workspace structure and is allowed to say “no” to random new wikis and boards
Start complementing Notion with other tools (instead of forcing it) if:
  • You routinely write first drafts elsewhere because Notion feels heavy
  • People DMs and share screenshots of pages instead of linking to a canonical place
  • Your most important work decisions are not easily findable within 10 seconds
Bottom line: there is no moral victory in “fully using all of Notion.” If it reduces the number of places you look for answers and makes collaboration clearer, keep it central. If it mainly adds a layer of guilt and friction, shrink its role until it’s just a clean, simple wiki and light project hub, and let more focused tools handle capture and execution.
