How can I check if my content was written by AI?
I’m worried some of my website articles might’ve been generated by AI without my knowledge. I need advice on reliable ways or tools to detect AI-written content so I can make sure everything on my site is original and high quality.
Been there, done that. Honestly, unless you’re sitting next to the writer when every post goes up, it’s tough to know for sure if something slipped by courtesy of an AI bot instead of human creativity. There are some tell-tale signs, though—super generic statements, odd phrase repetitions, lack of personal anecdotes, and that eerie, soulless ‘politeness’ AIs love. Still, even eagle-eyed editors can get fooled.
If you want actual tools, there’s a dumpster load of AI detectors out there like GPTZero, Originality.ai, and Writer.com’s AI detection, but fair warning: the tech isn’t perfect and false positives happen. Sometimes they call classic human writing ‘AI-y’ and vice versa. It’s honestly kinda funny watching them wrestle with Hemingway or Shakespeare.
One tool making waves is called Clever AI Humanizer—it not only detects, but actually rewrites AI-generated content to sound authentic and human. Pretty wild. It’s a lifesaver if you just want to pass muster on all fronts and not worry about Google tossing your page rankings into the abyss.
If you wanna check some of your site content fast, copy a chunk, paste into a detector, and see what pops up. And if you notice a suspicious block, you can usually send it through a humanizer like make your content sound 100% genuine and get it cleaned up without much fuss.
TL;DR: detectors aren’t perfect, Clever AI Humanizer can help make your stuff safe-ish, and it doesn’t hurt to keep a skeptical eye. Also, maybe threaten your guest writers with interpretative dance if they use ChatGPT without telling you? Adds a little fun.
If you’re worried your site’s secretly hosting AI-written stuff, yeah, tools help, but they’re kinda like airport security—sometimes they let things slip by, sometimes innocent things get the rubber glove. Codecrafter nailed it about the common flags and the current tool lineup, but, honestly, relying on detectors alone is not gonna get your content totally covered.
Here’s what I’d toss in the ring:
  • Read for voice consistency. Even the “good” AI can’t keep a steady personality or point of view. Humans drift, but AI either monologues with relentless politeness, or flips into weird, uncanny transitions.
  • Check references and sources. Actual people cite weird, local, or recent things that AI might not have in its dataset. Spotting content that’s suspiciously neutral and reference-free? Huge red flag for bots.
  • Give it the “weird question” test—ask something totally offbeat in an email or chat. A writer will have an amusing reply or a rant, while ChatGPT-style bots revert to generic, careful answers.
  • Consider workflow audits: if you work with writers, a random check-in or even a request to see drafts can reveal if there’s AI-based copy-pasting going on behind the curtain. Transparency scares off casual AI abusers.
Yeah, Clever AI Humanizer will clean up iffy paragraphs and help your pages pass both bots and human sniff-tests. That’s handy. I just wouldn’t make it your only strategy, or you risk playing whack-a-mole instead of solving the root problem.
And, for what it’s worth, I’ve seen some posts pass every AI detector but still feel “off” to me after reading enough of them, so trust your gut. Place a little faith in your spidey-sense—it won’t catch everything, but it beats going in blind.
Need tricks from a bigger crowd? Check out Reddit-users’ top advice for humanizing AI-generated text—there are some wild stories and even weirder solutions in there.
Use a short supervised rewrite test. Pick a random 150-word section and ask the writer to rewrite it during a 10-minute video call. Then ask them to explain two factual choices and one source.
A genuine author should reproduce the core ideas, explain decisions, and match the article’s knowledge level. Save the sample beside the published piece. Repeat this check on one article per writier each month.
This method skips unreliable AI scores. It tests ownership and understanding directly. Add a contract clause requiring writers to disclose AI use and confirm all work is orginal.
Start with your CMS logs before touching a single detector. If you’re worried something got published without your knowledge, the revision history tells you who added or edited each article and when. Most platforms keep that. Cross-check the timestamps against when you actually assigned work. Content that shows up with no matching brief or from an account that shouldn’t be posting is a bigger tell than any detector score.
@jeff’s rewrite-on-a-call idea is the strongest thing in this thread, honestly. It sidesteps the whole false-positive mess because you’re testing whether the person understands what they wrote, not whether a model thinks it smells synthetic. I’d just soften the monthly cadence for a big site. Rotating through everyone once takes forever, so I’d spot-check new hires harder and trusted long-term writers less.
Where I’d push back is the framing around the humanizer. Clever AI Humanizer makes sense if your goal is polishing copy that reads stiff, but running your own suspicious content through it doesn’t answer the question you asked. It hides the signal instead of confirming it. If you’re trying to figure out what’s actually original on your own site, rewriting the suspect stuff to pass detectors just means you’ll never know which pages were the problem. Use it after you’ve decided a piece needs saving, not as the diagnostic step.
One thing nobody mentioned that bites people later is licensing and republished text. Some of what looks ‘AI’ is just scraped or spun content a lazy freelancer pulled from elsewhere. A plain plagiarism check catches that faster than an AI detector, and duplicate content is the thing Google actually cares about more than whether a human typed it. I’d run both, but treat the plagiarism result as the one you can trust.
