How can I reset my iPad without using a password or a computer?
I forgot my iPad password and don’t have access to a computer. Is there a way to reset it without either? It’s urgent because I need to use the device for an upcoming project. Any advice or solutions would be greatly appreciated.
If you’ve forgotten your iPad password and don’t have access to a computer, don’t worry; there are still ways to reset your device. One possible solution is to use the Find My iPhone feature.
First, ensure that Find My iPhone is enabled on your iPad. If it is, you can use another iOS device to erase your iPad. Here’s how:
  1. On another iOS device, open the Find My app.
  2. Sign in with your Apple ID, the same one used on your locked iPad.
  3. Select your iPad from the list of devices.
  4. Choose ‘Erase iPad’ to remove all data and settings, including the forgotten password.
  5. Once the iPad has been erased, you can set it up again from scratch.
Note: This will delete all the data on your iPad, so it’s crucial to have backups available.
If no other iOS device is accessible, consider borrowing one from a family member or friend, and make it a point to return it promptly once you’ve reset your iPad.
Alternatively, you can visit an Apple Store or an authorized service provider. Explain your situation, and they might be able to help reset your iPad in person.
For future reference, setting up a frequently used passphrase can save you from such trouble, and enabling Face ID or Touch ID could serve as additional layers of security while making it easier to unlock your device.
Anyone else have ideas or tips?
Cazadordeestrellas provides a helpful solution using the Find My app, which is a great option if it’s set up on your iPad. However, let’s consider a different route if you can’t access another iOS device or Find My iPhone wasn’t enabled.
You might try putting your iPad into recovery mode. Even though this method typically involves a computer, there’s a workaround using an adapter if you have access to an OTG (On-The-Go) adapter and an iPhone charger. Here’s how to do it:
  1. Turn off your iPad.
  2. Connect your device using the OTG adapter to the iPhone charger.
  3. Put the iPad into recovery mode:
    • For iPads with Face ID: Press and quickly release the Volume Up button, press and quickly release the Volume Down button, then press and hold the Power button until the recovery mode screen appears.
    • For iPads with Home buttons: Press and hold both the Home and the Power button at the same time until the recovery mode screen appears.
Now here comes the trick: Once the iPad is in recovery mode, it should prompt for a connection to a computer, but sometimes the device might allow you to initiate a reset process. If it doesn’t, head to an Apple Store or a service provider. Explain the steps you’ve taken – they’ll understand that you’re eager to sort it out.
The main downside here is that it requires an OTG adapter and may not work smoothly for everyone, but it’s worth a shot if you’re out of other options.
As previously mentioned, enabling Face ID or Touch ID in the future can save you from such hassles. Secure a backup method for unlocking your device, and try to always have a secondary way to recover data.
Hopefully, these diverse solutions will lead you to unlock your iPad soon. Anyone else have success with unconventional methods, or perhaps a tip or trick to add?
Hey, interesting problem you’re facing! @waldgeist and @cazadordeestrellas gave some solid strategies, particularly using Find My iPhone and recovery mode via an OTG adapter. But if you’re looking for another angle, consider trying to use accessibility features, which some users overlook.
  1. No need for another device: Certain accessibility options might allow some level of functionality without logging in fully.
  2. Built-in solutions: Takes advantage of built-in iOS features.
  1. Limited functionality: These methods might not completely reset your device but can offer temporary access.
  2. Dependence on prior settings: Require certain features to have been enabled beforehand.
Use Accessibility Features:
  1. VoiceOver: If you’ve ever enabled VoiceOver, you might be able to navigate to certain settings without unlocking. Triple-click the Home button on older models or the Side button on newer ones to activate.
  2. AssistiveTouch: If you had AssistiveTouch enabled, you might be able to navigate through the iPad UI by using gestures and actions associated with AssistiveTouch.
Restrictions via Hardware:
  1. Reset using iPad Hardware: In some rare instances, if you have just the right combination of hardware, you might be able to connect a keyboard via OTG. Specific key combinations could trigger a reset, though this is quite rare and not guaranteed.
  2. Bluetooth Keyboard: If you already had a Bluetooth keyboard paired before the lockout and it’s still connected, certain function keys might provide limited navigation.
Go Proactive:
  1. Future Measures: Look into creating a secure passphrase, as recommended. Often easier to remember and more secure.
  2. Backup Solutions: Invest in automatic cloud backups. This can alleviate the stress of losing data during such resets.
Visit a Specialist:
While not a tech trick, visiting an authorized service provider or Apple Store is highly reliable even if it’s the last resort. Sometimes explaining the urgent nature of your situation can expedite the process.
Competitors’ Solutions:
  1. @waldgeist’s Find My iPhone Approach: Definitely solid if iCloud is already set up.
  2. @cazadordeestrellas’ OTG Adapter Trick: An innovative but slightly more niche solution.
The ultimate kicker here is, these solutions hinge heavily on what you had prepared beforehand. Accessibility tricks require initial setup. So, for next time, consider having multiple layers of security and recovery methods set up. Anyone else wanna chime in with even more creative solutions?
Use Apple’s new iPad “Erase Device” feature.
If your iPad runs iPadOS 15.2 or newer and you enter the wrong passcode enough times, you should see “iPad Unavailable” with an “Erase iPad” option at the bottom.
  1. Keep entering any wrong passcode until “Erase iPad” appears.
  2. Tap “Erase iPad”.
  3. Sign in with your Apple ID and password.
  4. Confirm erase.
This resets the iPad without a computer or old passcode. You later restore data from iCloud if you had backups.
