How do I clear the cache on Safari for iPhone?
My iPhone’s Safari browser is running really slow and having trouble loading pages. I think it might be a cache problem, but I’m not sure how to clear it. Can someone guide me through the steps to clear the cache on Safari for an iPhone? Thanks!
Yup, sounds like clearing the cache could help speed up Safari on your iPhone. Here are the steps to get that done:
  1. Open the Settings app on your iPhone.
  2. Scroll down and tap on ‘Safari.’
  3. Scroll to the bottom and tap on ‘Clear History and Website Data.’
  4. A confirmation pop-up will appear—tap ‘Clear History and Data.’
This should wipe out all the cache and cookies that might be bogging down Safari. Just a heads-up: doing this will log you out of websites you’re currently signed in to, so you’ll need to log back in.
Additionally, if you want to clear history but keep browsing data intact, go to Settings > Safari > Advanced > Website Data, and then tap “Remove All Website Data.” This can be a bit more targeted while still giving you a speed boost.
Hope your Safari starts running like a cheetah again!
Learn the steps on how to clear cache on iPhone in 2025 from this detailed Reddit tutorial.
While @viajantedoceu covered the basics pretty well, I’d suggest an alternative approach for those who want to start from scratch or dive even deeper into solving sluggish Safari performance on an iPhone.
  1. Settings Reset: In some cases, you might want to go beyond just clearing the cache. You can reset all your settings (though this is a bit more extreme and not always necessary):
    • Go to Settings > General > Reset > Reset All Settings. This won’t delete any of your data but will reset your system settings.
  2. Close All Tabs: Open Safari, then press and hold the “Tab” icon (two squares), tap on “Close All Tabs.” Restarting with a clean slate can sometimes work wonders for performance.
  3. Disable Extensions: If you have any Safari extensions enabled, try disabling them. Recently added extensions might be the culprit:
    • Go to Settings > Safari > Extensions, and toggle them off to see if it makes a difference.
  4. Check for Updates: Sometimes, software updates can include performance improvements and bug fixes:
    • Ensure your iPhone has the latest iOS version installed by going to Settings > General > Software Update.
  5. Advanced Data Management: For targeted data clearance:
    • Navigate to Settings > Safari > Advanced > Website Data > Edit and selectively delete data from specific sites that you think might be causing trouble.
Remember, sometimes the cache isn’t the only issue. If the problem persists, consider checking your network connection or consulting Apple Support for more detailed troubleshooting.
For a detailed guide on improving iPhone browser performance, check this tutorial: How to Clear Cache on iPhone in 2025.
Hope this helps turbocharge your Safari! :rocket:
Try offloading and reinstalling Safari related data through iCloud sync.
  1. Go to Settings, tap your name, tap iCloud.
  2. Tap Show All under Apps Using iCloud.
  3. Turn off Safari, choose Keep on My iPhone.
  4. Wait 10–20 seconds.
  5. Turn Safari back on, choose Merge.
This refreshes your sync data, which often fixes slow loading.
If it still feels laggy, restart your iPhone once.
