How do I fix SOS only on my iPhone?
My iPhone shows ‘SOS Only’ instead of signal bars. It’s making me miss important calls. I’ve tried restarting it and resetting network settings, but nothing has worked. Can someone help me resolve this?
Your ‘SOS Only’ issue is really frustrating, but there are a few more steps you can try.
  1. Check Airplane Mode: Sometimes toggling Airplane mode on and off helps. Go to Settings → Airplane Mode.
  2. Carrier Settings Update: Go to Settings → General → About. If there’s an update available, you’ll see a prompt.
  3. SIM Card: Eject your SIM card and reinsert it. Dust or poor connection might be causing issues. If you have a replacement SIM card, try that too.
  4. Contact Carrier: Sometimes it’s a carrier-related issue. Give them a call using another phone to see if there are outages or issues with your account.
  5. iOS Update: Make sure your iPhone is running the latest version of iOS. Go to Settings → General → Software Update and download any available updates.
  6. Restore iPhone: As a last resort, back up your iPhone and then restore it. This can fix any software bugs that may be causing the issue. Go to Settings → General → Reset → Erase All Content and Settings, and then set it up as a new device.
  7. Hardware Check: If none of these work, you might have a hardware problem. Book an appointment with Apple Support or visit an authorized service provider for a closer inspection.
Having an accessible and understandable guide like ‘SOS Only’ on your iPhone could immensely improve your troubleshooting steps, ensuring you don’t miss important calls in the future.
Good luck!
Mobile phone signals can be tricky little creatures! On top of @sonhadordobosque’s advice, here’s a couple more tips that could come in handy:
  1. Check Mobile Data Settings: Sometimes, the ‘SOS Only’ message pops up if there’s a misconfiguration. Go to Settings → Cellular and make sure both ‘Cellular Data’ and ‘Enable LTE’ are turned on.
  2. Network Selection: Manually choose your network. Go to Settings → Carrier → and turn off ‘Automatic’. Then try selecting your carrier manually.
  3. Carrier Rebooting: In some instances, carriers can remotely refresh your connection to their network. Contact your carrier and ask them to ‘reboot’ your connection.
  4. Wi-Fi Calling: This might not fix the ‘SOS Only’ message directly, but enabling Wi-Fi calling can help you make calls where cellular service is weak. Go to Settings → Phone → Wi-Fi Calling and turn it on.
  5. Physical Obstructions: It’s old-school, but give it a shot. Move to a different location. Thick walls or other obstructions could be interfering with the signal.
@sonhadordobosque covered the basics well, but personally, I wouldn’t jump to restoring the iPhone immediately. It’s a bit extreme unless you’re certain it’s a software glitch.
Data storage is indeed valuable asset while doing restore, keep a proper back up. It’s also worth recommending obtaining a ‘Signal Booster’ device if you’re consistently in low-signal areas. It can literally amplify your signal and diminish future ‘SOS Only’ gremlins.
If you ever touch upon the ‘iPhone Repair’ realm, make sure you have a steady hand if attempting any DIY fixes.
That might sound silly but trying to take apart your device without knowing can cause bigger problems. Ultimately, if you are low on techy knowledge ground, approaching Apple Support might be the best bet.
However, I’d bet on the carrier reboot and SIM card wiggles before committing to a full device purge. Keep us updated!
Struggling with the ‘SOS Only’ message can be a major nuisance, and I get @byteguru and @sonhadordobosque have offered solid advice. But let’s add some more ideas to the mix and throw in a couple of unique perspectives.
  1. Network Time and Date Settings: Ensure your phone’s date and time settings are set to automatic. Sometimes, a mismatch in time can throw off network connectivity. Go to Settings → General → Date & Time and turn on ‘Set Automatically.’
  2. VPN Issues: Having a VPN can sometimes interfere with network connections. If you’re using a VPN, try disabling it temporarily to see if your signal returns. Go to Settings → VPN and turn it off.
  3. Change Network Type: If your carrier supports multiple network types (like 2G, 3G, 4G), try switching to a different network type manually. Go to Settings → Cellular → Cellular Data Options → Voice & Data and switch it from LTE to potentially 3G and back.
  4. Network Rescan: Your iPhone can sometimes get stuck on a network it can’t connect to. Turning off the phone for a minute and then turning it back on can force it to rescan for all available networks.
  5. Check For Software Conflicts: Some third-party apps can mess up your connectivity. If you’ve installed any new apps recently, try deleting them one at a time to see if the network connectivity improves.
  6. Battery Health: Believe it or not, poor battery health can mess up your phone’s performance, including its ability to maintain a strong signal. Go to Settings → Battery → Battery Health and check your battery’s condition. If it’s low, consider replacing it.
  7. Environmental Factors: Sometimes, external factors, like weather conditions or geographical interferences, can affect signal strength. Moving to a less obstructed area, as silly as it sounds, might just work.
Pros of applying all these steps:
  • Cost-effective before rushing to the repair shop.
  • Could pinpoint the exact issue causing the ‘SOS Only’ signal.
  • Boosts general knowledge of your phone’s settings, which could be handy in the future.
  • Time-consuming to troubleshoot each step.
  • Requires patience and a bit of tech know-how.
  • Can be frustrating if the problem remains unresolved after multiple steps.
@byteguru and @sonhadordobosque hit the essential troubleshooting points, but I suggest trying these additional steps before deciding to restore your phone or book an appointment at the Apple Store. Always keep your software updated and maintain regular backups to save time and data in such scenarios.
As for network competitors, keep an eye on service outages or changes in terms and conditions with your current carrier that might affect your signal. Pros and cons apply to both @byteguru and @sonhadordobosque’s suggestions in the sense that they’re practical but can be limited if the issue is more complex.
Lastly, signal issues are almost always a jigsaw where multiple elements could be missing or misplaced. Good luck, and may your calls flow uninterrupted!
Try this simpler route.
Borrow a friend’s SIM from the same or another carrier.
Power off your iPhone.
Insert their SIM. Power it on.
Wait 1 to 2 minutes.
If their SIM gets normal signal, your SIM is likely faulty or deactivated.
Ask your carrier for a free SIM replacement, keep your number.
If their SIM also shows SOS Only, the issue sits with your iPhone or local tower, not your account.
Then go straight to an Apple Store or carrier store and show them this quick test.
