How do I forward a text message on my iPhone?
I received an important text message that I need to forward to a coworker. I’ve tried looking through the messaging app but can’t figure out how to do it. Can someone guide me on how to forward texts on an iPhone?
Forwarding a text message on an iPhone is pretty straightforward once you know where to look. Here’s how you can do it:
  1. Open the Messages app on your iPhone.
  2. Find the conversation that contains the message you want to forward.
  3. Tap and hold the specific message bubble until a menu pops up.
  4. Tap ‘More…’ from the pop-up menu.
  5. You’ll see checkboxes appear next to each message in the thread. Make sure the one next to the message you want to forward is checked.
  6. Tap the forward icon (a curved arrow) in the bottom-right corner of the screen.
  7. A new message window will open, and the selected message will be copied into the text field.
  8. Enter the contact information of your coworker in the ‘To:’ field.
  9. Hit the send button.
That should do it! It’s always a bit hidden, but once you know the steps, it’s pretty quick. Apple always manages to hide these useful features behind a long press or swipe! If you still have trouble finding it, you might want to try using a more intuitive messaging app; sometimes built-in apps aren’t the most straightforward.
Oh, and if you’re looking to make the interface more user-friendly overall, sometimes exploring third-party apps can be a game-changer. But for simple tasks like forwarding messages, the built-in Messages app should suffice.
Well, I see @viajantedoceu covered the basic steps pretty well. I just want to add a little twist to it. Sometimes, Apple’s default interfaces can feel a bit convoluted. If you’re forwarding messages frequently, you might consider using Siri to streamline the process. Here’s a neat trick:
  1. Activate Siri by holding the side button or saying ‘Hey Siri’.
  2. Say, “Forward this message to [Coworker’s Name]”.
  3. Siri will ask for confirmation before sending it.
Oh, and another thing you might find useful is using iOS’s shortcuts feature. You can create a shortcut to forward messages which can be triggered by a voice command or tap of a button.
  1. Open the Shortcuts app.
  2. Tap the plus sign (+) to create a new shortcut.
  3. Add the action “Send Message”.
  4. Select your coworker as the recipient.
  5. Add another action “Get Clipboard”.
  6. Save the shortcut and name it something like “Quick Forward”.
Now, whenever you need to forward a message, just copy it and run your shortcut. This might seem a bit overkill for a single message, but if you’re routinely forwarding info, it’s a real timesaver. Plus, it kind of showcases Apple’s hidden strengths in making repetitive tasks easier with just a bit of setup.
Also, if you find yourself struggling with Apple’s built-in apps, consider looking into alternative messaging apps that offer a more intuitive interface. Apps like Telegram or WhatsApp might be more straightforward for your needs, and you can often forward messages even more easily through those platforms.
To touch on what @viajantedoceu mentioned about exploring third-party options, it’s sometimes worth the hassle. Not all iPhone users realize there’s a whole world outside the native ecosystem. It’s a slight deviation from the core question, but exploring additional tools in the App Store that cater to your specific operations could bring unexpected benefits.
Forwarding texts can be quick and easy once you get the hang of it, but being open to evolving your tech ecosystem can streamline your workflow even more. Give Siri and shortcuts a whirl; who knows, it might just click for you!
It seems like @sternenwanderer and @viajantedoceu have covered most of the basics for forwarding a text on an iPhone. There’s really no denying that the process can be a bit convoluted at first.
However, I have a slightly different take on it. One thing I’ve noticed is that the iPhone’s Messages app, while functional, lacks a certain fluidity that other platforms like WhatsApp or Telegram excel in. Both apps streamline message forwarding with features like group chats and quick share options, which can make them worth considering if you often need to forward messages.
But since we’re focused on the iPhone here, another pro is that despite the initial learning curve, once you get the hang of it, the built-in app integrates perfectly with the broader Apple ecosystem. You can use Siri, as @sternenwanderer suggested, which makes things significantly faster. However, I’d like to add that Siri isn’t always reliable depending on your accent or background noise levels, so it’s not the be-all and end-all solution. Moreover, while creating Shortcuts as @viajantedoceu pointed out is a nifty hack, it’s also a bit much for something as simple as forwarding a single text.
Here’s an alternative angle: consider using voice notes or even email. If the message you need to forward contains critical details, recording a quick voice note and then sending it via iMessage can sometimes get the point across more effectively. It’s a less tech-heavy but equally impactful approach. Similarly, forwarding the content via email can ensure that your coworker gets the full context without formatting issues, especially if it’s a longer message. Plus, emails are superior when it comes to searching and archiving, something the Messages app isn’t particularly great at.
It’s also worth considering that sometimes switching between apps might not be as cumbersome as it sounds; Apple’s clipboard history can really help if you’re juggling multiple platforms. And for those curious about alternatives, you might want to give apps like Signal or Viber a whirl—both offer end-to-end encryption and potentially simpler interfaces.
In short, while the iPhone’s Messages app does the job and integrates seamlessly into the Apple ecosystem (big pro), it falls a bit short in terms of user-friendly navigation and quick accessibility for frequent tasks (con). If you don’t mind venturing into the App Store, other messaging apps can offer a more streamlined experience, but you’ll miss out on Apple ecosystem features. So it’s a trade-off.
Good points above. Siri, Shortcuts, voice notes, email, and alt apps were noted. Try a simpler route, screenshot and send.
Steps:
  1. Open Messages, go to the thread.
  2. Get the message bubble on screen.
  3. Press Side and Volume Up to screenshot. On older iPhones, Side and Home.
  4. Tap the thumbnail, crop to teh text, hide names if needed.
  5. Tap Share, pick Messages, choose your coworker, hit Send.
This keeps exact wording, avoids formatting quirks. I use it for ETA texts and recieved codes, works fast.
