How do I schedule a message to send later on iPhone?
I sometimes need to send messages but want them to go out at a specific time instead of right away. I know there might be ways to schedule things like this on an iPhone, but I can’t figure out how to do it. Can anyone help guide me on how to set a message to send later?
Yoooo, so here’s the tea :tea:: there’s no official iPhone feature to ‘schedule’ a message in the regular Messages app (super annoying, right?). BUT you can totally hack the system using the Shortcuts app. It’s a lil’ clunky but gets the job done.
STEP 1: Open Shortcuts app (pre-installed, no need to go app store hunting :sunglasses:).
STEP 2: Tap ‘+’ to create a new automation. Select ‘Personal Automation’ → Choose ‘Time of Day’.
STEP 3: Set the time you wanna send the message and tap ‘Next’.
STEP 4: Add Action → Choose ‘Send Message’. Type the message and select the recipient.
STEP 5: Toggle OFF ‘Ask Before Running’ (so it doesn’t bug you for permission later).
The catch? It’s like a one-time schedule. Wanna re-use it? You’ll have to edit the automation each time :woman_facepalming:. Apple really said, “Let’s make this unnecessarily difficult.”
For folks needing advanced scheduling like a pro, download apps like Scheduled or use WhatsApp Business if the person you’re messaging is cool with WhatsApp. iOS users basically gotta get creative or deal with Apple’s weird limitations. :v:
Scheduling messages on iPhone is such an exercise in patience, isn’t it? Like, why hasn’t Apple added this as a basic feature in the Messages app? Anyway, while @viajantedoceu is spot-on with the Shortcuts method, I personally find it a bit… meh. Clunky is definitely the word for it. If you’re ok with alternatives, here are a couple of other ways to make it work without pulling your hair out:
  1. Third-Party Apps: The ‘Scheduled’ app might save you some time. It lets you prepare messages and sends you a notification to send it manually at the scheduled time. Annoying that it still requires manual tapping, but honestly, it’s cleaner than fumbling through Shortcuts every time.
  2. Email Workaround: If it’s something formal, why not draft an email? Using the Mail app on iPhone, you can now schedule emails to go out at specific times without breaking your flow. Not a text, sure, but works in some contexts.
  3. WhatsApp or Telegram: If you and the recipient are cool with using these apps, they have slightly better options for scheduled messages via business accounts or bots.
Here’s a confession: I gave up on this nonsense a while ago and just use reminders to nudge me to send important messages at set times. Low tech, I know, but sometimes the old-fashioned ways slap harder than dealing with Apple’s lack of features.
Honestly, for a trillion-dollar company, it’s wild they can’t add a basic schedule feature to Messages. Meanwhile, Android’s out here naming galaxies AND scheduling texts. :woman_shrugging:
Alright, here’s a breakdown for those still navigating through Apple’s oddly restrictive text-scheduling landscape:
Honestly, if you’re relying on iMessage, you’re stuck working with Shortcuts (solidly covered above, shoutout to the breakdown), but let’s ditch “meh workarounds” when you’ve got other, slightly smarter routes:
1. Reminders with Quick Links to Messages (An underrated trick!)
Instead of automations, try using the Reminders app. Create a reminder with your phrased-out message and include a direct link to your recipient. At the scheduled time, it’ll pop up, and you just hit send. Sure, this isn’t full auto-send, but it flows better than fumbling with automations. Bonus: You don’t need to edit or delete the Shortcut every time.
2. Use Calendar Apps with Notes
Not ideal but functional: Some productivity apps like Fantastical (yes, it costs, but worth it if you’re detail-driven) let you create events with quick note-taking. Jot down your text inside, so when the scheduled time reminds you, you’re ready in a second.
3. Third-Party App ‘Scheduled’ Pros and Cons
Even @jeff gave it a nod! ‘Scheduled’ is NOT perfect, here’s why:
  • Preps texts in advance.
  • Notifications act as reminders (better for texting with iMessage and other platforms).
  • Manual tapping to send – defeats true scheduling.
  • Premium subscription needed for advanced features.
4. Write-Now, Send-In-Email
If you’re already crafting something semi-formal, try scheduling emails via the iPhone Mail app itself. It’s finally evolved to allow delayed sends. (Thanks, Apple, for at least improving here. :joy:)
Why Hasn’t Apple Stepped Up?
iOS is clearly lagging behind Android on this – Android users can schedule texts directly without apps or second-guessing. Apple probably sees it as low-priority because simple features like these don’t boost hardware sales. Frustrating for us though, right?
If you need long-term solutions for regular text scheduling, maybe adopting WhatsApp Business (super useful as @viajantedoceu mentioned) for casual and professional uses isn’t a horrible idea. But let’s be real – the need for native scheduling remains criminally overlooked.
Use Notes plus copy paste.
  1. Open Notes.
  2. Start a note called “Scheduled texts”.
  3. Write your message, put the date and time on top.
  4. Turn on a reminder for that note: tap the three dots, tap “Pin Note”, then add it to Reminders with a time.
  5. When the alert fires, open the note, copy the text, paste into Messages, send.
You avoid Shortcuts, no extra apps, and it works for one off or repeated texts.
