I used AI to draft some writing, but it sounds stiff, repetitive, and too obvious for my audience. I need help making AI text sound more natural, conversational, and human without losing the original meaning. Looking for tips on editing AI content for better tone, flow, and readability.
Best fix is this. Stop editing words first. Edit voice.
Do 5 passes.
Read it out loud.
If you run out of breath, cut the sentence.
If you cringe, rewrite it. -
Kill repetition.
AI repeats structure more than words.
Example:
‘You need to improve clarity. You need to improve tone. You need to improve flow.’
Change it to:
‘Improve clarity, tone, and flow.’ -
Add a real point of view.
AI sounds flat becuase it avoids preference.
Pick one.
‘I’d keep this short.’
‘Your audience won’t care about the backstory.’ -
Swap obvious words for normal ones.
‘Utilize’ becomes ‘use.’
‘Additionally’ becomes ‘also.’
‘Individuals’ becomes ‘people.’ -
Add human friction.
A tiny aside helps.
‘That part felt off.’
‘This is the only section I’d keep.’
Good test. Paste a paragraph into Hemingway or Grammarly, then compare before and after. If every sentence has the same length, it still sounds fake.
One more thing. Keep some imperfections. Over-cleaning makes it robotic agian.
I’d add one thing to what @byteguru said: stop trying to make it sound “human” in the abstract. Make it sound like a specific person talking to a specific reader. That shift fixes a lot.
A few things that help:
- Put the audience back in. AI drafts often sound generic because they ignore who’s reading.
- Add concrete detail. Not “improve productivity,” but “cut the 20-minute back-and-forth.”
- Let some sentences do less. Not every line needs to explain itself.
- Use transitions people actually say: “but,” “so,” “still,” “here’s the thing.”
- Cut fake certainty. Humans hedge sometimes. “Probably,” “in most cases,” “usually” can help.
I actually disagree a little with the “keep imperfections” advice, becuase some people use that as an excuse to leave clunky writing untouched. Keep personality, sure. Keep slop, no.
Best test: would a real person text or say this out loud without sounding weird? If not, it still needs work.
I agree with keeping personality without keeping sloppy writing. My simpler approach is to stop editing the AI draft sentence by sentence.
Copy its key facts into a seperate note, then close the draft. Write a fresh paragraph using only those facts. You won’t have its wording in front of you to copy.
Compare your version with the orginal afterward. Restore any missing facts, numbers, or qualifications. For a longer piece, work through one paragraph at a time.
Expect to spend more time on this than you think, because most of what makes AI writing sound fake isn’t word choice at all. It’s that the draft rarely says anything a human felt strongly enough to write down. You can swap every ‘utilize’ for ‘use’ and still end up with a paragraph that any of a thousand people could have produced. So before polishing, ask whether the point itself is worth making. If it isn’t, no amount of tone editing saves it.
The approach from @qadata4 is the one I’d actually trust here. Rewriting from the facts instead of editing line by line breaks the AI’s rhythm completely, which is the hardest thing to fix when you stare at the original wording. Editing in place tends to leave the skeleton untouched. You end up with human vocabulary draped over a robotic sentence order.
Where I’d gently push back is the idea that transitions and hedges alone fix the flatness. @himmelsjager is right that ‘but’ and ‘so’ read more natural than ‘additionally,’ but the deeper tell is predictable paragraph logic. AI loves to state a claim, support it, then restate the claim. Humans drift. We bury the real point in the second sentence, or jump to an example and never circle back. If your structure is too tidy, it still reads synthetic even with casual connectors sprinkled in.
One practical thing people forget: read it the next day, not right after editing. When you edit fresh off the draft, you’re still half-anchored to the AI’s phrasing and you’ll approve lines you’d never actually say. A little distance makes the stiff sentences jump out on their own. And skip the detector tools for judging this. They measure something closer to perplexity than to whether a real person would say it out loud, so they’ll flag clean human writing and wave through dull text that happens to be worded unusually.
