How To Update Android
I’m trying to update my Android phone to the latest version but I’m confused by the options in the settings and not sure which steps are correct for my device and carrier. I’m worried about losing data or choosing the wrong update method. Can someone walk me through the safest way to update Android and what I should back up or check before starting?
Short version: backup first, then update from Settings, not from random popups or sites.
Here is a clean set of steps that works on most Android phones and avoids data loss:
  1. Check your current version
    Settings > About phone > Android version
    Note your version and model. Helps if something goes wrong.
  2. Backup your stuff
    • Google backup:
    Settings > Google > Backup > turn on “Backup by Google One” (or similar)
    Tap “Back up now”
    • Photos:
    Open Google Photos > profile pic > Photos settings > Backup > turn on
    • WhatsApp or similar chat apps:
    Open app > Settings > Chats > Chat backup > run a backup
    • Optional: plug into a PC and copy DCIM, Downloads, Documents folders
  3. Plug in and use Wi‑Fi
    Updates often need over 2 GB.
    Battery 50 percent or more, or keep it on the charger.
  4. Use the official system update path
    Typical path:
    Settings > System > System update
    or
    Settings > Software update
    or
    Settings > About phone > Software info > Software update
Avoid:
• Popups in browsers telling you to “Update Android”
• APKs from random sites
Only update through Settings.
  1. What the options mean
    You might see:
    • Download and install: pulls the update now and installs after download
    • Schedule install: installs at night while your phone is idle
    • Check for updates: pings your vendor or carrier for newer builds
If you use a carrier model (AT&T, Verizon, T‑Mobile, etc), you often need:
• SIM card inserted
• Network signal on that carrier
Large updates sometimes roll out in waves. If you see “Your system is up to date” but you know a newer version exists, your IMEI is probably not in the current rollout batch yet.
  1. During install
    Screen might go black, logos, progress bars, reboots.
    Do not power off manually.
    Do not pull the battery if your phone even has one.
    Normal for it to take 5 to 20 minutes for minor updates, 20 to 60 for a full Android jump.
  2. After update
    • Go back to Settings > About phone > check new Android version
    • Open Play Store > profile pic > Manage apps and device > Update all
    • Log into apps that logged you out
    • Check photos, messages, contacts are there
  3. If storage is low
    If you see errors like “not enough space”
    • Settings > Storage > clear cache for big apps like Chrome, Facebook, TikTok
    • Delete old videos or move them to PC or cloud
    Aim for at least 5 to 8 GB free for major updates.
  4. If you fear data loss
    Data wipes during a regular OTA update are rare.
    Factory reset is the part that wipes data, and that sits in:
    Settings > System > Reset options
    Unless you tap that and confirm, your data stays.
    A backup still protects you if something glitches, or if you need a repair later.
  5. Special cases
    • Older phones (around 3 to 4 years old) often stop getting big Android version jumps and only get security patches.
    • If your phone is rooted or uses a custom ROM, do not use stock OTA. Use the ROM instructions instead.
    • If your phone is from a different region than your carrier, updates might be delayed or blocked.
If you post your phone brand, model, and carrier, plus what you see under Settings > System > System update, people here can walk you through the exact buttons to tap so you do not hit the wrong option.
Short version: your data is pretty safe as long as you stay away from factory reset and sketchy “update Android now!” popups.
@sternenwanderer already covered the standard checklist nicely, so I’ll hit the confusing bits you’re probably staring at on your screen and when you should (and shouldn’t) tap them.
1. The scary options you’ll see
In your system update screen you’ll usually see some combo of:
  • Download or Download and install
    Pulls the update from your phone maker / carrier. Safe.
  • Install now
    Only shows up after the download. Phone will reboot, you won’t lose data.
  • Schedule install / Install later / at night
    Same update, just runs while you sleep. Also safe.
  • Pause download
    Just pauses, does not cancel or break anything.
You can tap Download and still change your mind about when to install. What you should not see is anything in a browser tab, random app, or notification that opened a web page to “Update OS” and asks you to download an APK. Close that.
2. What actually risks your data
There are only a few things that really threaten your data in this context:
  • Factory reset / Erase all data
    This is in Settings > System > Reset (or similar). This is the nuclear button. Normal system updates do not touch this.
  • Flash tools / PC utilities like Odin, MiFlash, SP Flash Tool, etc.
    These are advanced methods and often require wiping data. If you’re not explicitly following a guide that mentions these, you’re not using them.
  • Unlocking bootloader / rooting
    Bootloader unlock typically wipes everything once. Regular OTA updates do not do this.
If you stay inside Settings > System (or Software) update you’re in the safe playground.
3. Carrier weirdness and what to try
Since you mentioned carrier confusion, a few gotchas:
  • Make sure your carrier SIM is in the phone when checking for updates. Some carrier-branded phones only offer updates on that network.
  • If it says “Your system is up to date” but you know a newer Android exists:
    • Your carrier might not have approved it yet for your specific model.
    • Rollouts can be staged by IMEI. You might just be in the “not yet” batch.
  • Using Wi Fi is enough to download, but sometimes first contact with the server needs mobile data active for carrier models. You don’t always need to actually use the mobile data, just have it on with a signal.
I slightly disagree with the idea that you always need 5 to 8 GB free. On many modern phones, ~3 to 4 GB can be enough for a typical OTA, but aiming higher is still smarter. If your phone is ancient and storage is tight, then yeah, more free space = less drama.
4. Super quick sanity checklist before you tap anything
  1. Check where you are:
    Settings > System (or General / Software) > System / Software update
    If you’re not in Settings, back out. Don’t use browser links.
  2. Make a basic backup:
    Even just turning on Google backup and Photos backup covers 90% of people. This doesn’t have to be perfect; just don’t skip it completely.
  3. Battery & Wi Fi:
    Over 50 percent battery or on charger, on Wi Fi.
  4. Hit Download and install, then let it reboot when it asks.
You shouldn’t lose data. After it boots, just double check your photos, messages, and apps. If something looks off or a specific option on your update screen is confusing, post the exact text of the buttons you see and your phone model + carrier, and people can tell you which one to tap without you playing Russian roulette with your data.
You’re already 90% safe if you stay inside Settings like @sternenwanderer said, so instead of repeating the route, here’s the stuff people only notice after they hit “Install”.
1. What actually changes when you update (and how to prepare for it)
Pros of updating:
  • Security patches fix exploits that apps and websites can abuse.
  • Bug fixes can stop random reboots, battery drain or camera glitches.
  • New Android versions sometimes improve standby battery and notifications.
  • New features: better permissions, privacy controls, UI tweaks.
Cons / annoyances:
  • Some apps misbehave for a day or two until they’re updated.
  • Battery may seem worse for 24–48 hours while the system “reindexes” (it is rebuilding caches in the background).
  • Layout changes: settings moved, icons changed, some toggles renamed.
  • Really old apps might stop working if they depend on outdated APIs.
If you’re nervous, pick a time when you don’t need the phone for at least an hour, so if a favorite app acts weird, you can calmly update/reinstall it.
2. The settings you should screenshot before updating
This is the part people forget and then think the update “broke” stuff.
Before you update, quickly screenshot these:
  • Home screen & launcher layout: So you can drag icons back if anything moves.
  • Keyboard settings: If you use custom languages, glide typing, or special layouts.
  • Wi Fi & hotspot settings: Especially if you use a custom DNS or Wi Fi proxy.
  • Notification settings for key apps: Banking, 2FA, messaging.
    Some updates reset notification channels to default.
If something feels different after the update, compare to your screenshots and fix directly instead of assuming the update destroyed everything.
3. When not to update immediately
I slightly disagree with the “just update right away” approach in every situation.
Consider waiting a bit if:
  • Your phone is more than 3–4 Android versions behind (like Android 8 to 12 in one jump).
  • It’s a work phone with VPN, MDM, or custom corporate apps.
  • You absolutely cannot risk any change in the next couple of days (travel, exams, events).
In that case:
  1. Check your exact model + “Android X update issues” on a reputable forum.
  2. If people are screaming about a critical bug on your model, wait for the next patch.
  3. Otherwise, schedule the update at night.
4. Storage & performance myths
@sternenwanderer is right that you don’t always need 5–8 GB free, but I’ll be more blunt:
  • If your internal storage is basically full (less than 1–2 GB free), every update is stressful.
  • After a big version jump, go to:
    Settings → Storage and clear cached data for big apps (browsers, social media, maps).
You usually do not need “cleaner” apps. They often make things worse. Use the system tools instead.
5. How to know if the update is “legit” without overthinking it
Quick checklist:
  • It appears only inside Settings → System / Software update, not in Chrome, not a pop‑up.
  • It doesn’t ask you to manually install a file or enable “Install unknown apps.”
  • The install step after reboot shows your phone manufacturer logo and an “Installing system update” or similar screen, not some random third party branding.
If any of that feels off, cancel and post a screenshot on the forum before proceeding.
6. After the reboot: quick health check
Right after the update finishes:
  1. Unlock the phone and give it 5–10 minutes without heavy use. Let it settle.
  2. Open:
    • Messages
    • Phone app
    • Photos / Gallery
    • Your main chat app
    • Your banking / 2FA app
      Confirm they open and look normal.
  3. Go to Play Store → tap your profile → Manage apps & device → Update all.
If something is really broken (constant crashes, no network, storage errors), then consider a cache partition wipe or last resort factory reset, but that is rare with stock OTA updates.
7. About “How To Update Android” guides and tools
A lot of search results for “How To Update Android” are:
  • Generic articles that push you to install random “optimizer” apps.
  • PC tools that want you to plug in your phone and promise “one click update.”
For a normal user, those are almost never required and can be risky. The built in updater is the intended method. Manual flashing and bootloader stuff are for advanced users who already accept the risk of wiping data.
8. Pros & cons of using a dedicated “How To Update Android” style guide
Since you mentioned being confused, curated guides or tools labelled like “How To Update Android” can be helpful, but be picky.
  • Everything explained in one place with screenshots.
  • Often cover specific brands and carriers more clearly than the generic Settings text.
  • Can list known issues per model and what to expect after updating.
  • Some are just ad farms suggesting junk apps.
  • If they tell you to sideload APKs for “system update,” that’s a red flag.
  • Outdated guides might reference menus or paths that changed years ago.
Use them for orientation, but always perform the actual update from your phone’s own Settings screen.
9. Where @sternenwanderer’s advice and mine differ slightly
  • They are more relaxed about jumping in as long as you stay inside Settings.
    I agree mostly, but add: if your phone is old or full, do a little housekeeping first.
  • They emphasize data safety, which is accurate. I’d add that “settings drift” and app behavior changes are the more common pain points, so prepping screenshots and checking notifications after the update matters more than people think.
If you post your exact phone model, Android version, and what the update screen says word for word, folks here can sanity check it and tell you if this particular update is one you should install now, schedule, or hold off on for a patch.
