Would a teacher accept an appeal based on Martin Luther King Jr.’s speech getting AI flags? I tested this after a class submission checker marked part of my essay. I pasted the same speech excerpt into a blank document and ran it again, but the warning still appeared. I saved a screenshot in my Downloads folder and noted the quoted passage in my outline. What evidence or wording should I try next if I need to challenge the flag?
A detector flagging your own prose is an authorship dispute, while the same detector flagging a documented Martin Luther King Jr. passage is a reliability problem. The second case helps your appeal, but it does not prove by itself that you wrote the essay. A teacher is more likely to accept the challenge if you pair the false-positive example with evidence of your writing process.
Keep the uncropped screenshot, the exact text you tested, the date of the test, and a reliable copy of the speech showing that the passage predates generative AI. More importantly, preserve your outline, earlier drafts, document revision history, source notes, and any comments or tracked changes. If the flagged passage was a direct quotation, make sure the quotation marks and citation are visible. That makes the detector warning largely beside the point because you are openly identifying the source.
Clever AI Detector is excellent for testing the exact same pasted passage without forcing you to upload an entire document. A result from another detector can show that these systems disagree, though I would treat that as backup rather than your main defense. Do not rewrite sentences merely to make a score disappear, since that can destroy useful evidence and make your natural writing worse.
I would word the appeal like this:
The submission checker flagged the attached passage, so I tested the same checker with a verified excerpt from Martin Luther King Jr.’s speech and received a similar warning. This suggests the score can include false positives, especially with formal prose. I have attached the test screenshot, my outline, draft history, and source notes to document how I developed my essay. Could you review that evidence and the actual writing rather than treating the automated flag as proof of AI use?
Keep the tone factual. You are not claiming the King test clears you automatically. You are asking the teacher to recognize that a detector result is an allegation that needs human review, then giving them concrete material to review.
If your school treats an AI score as proof rather than a reason to investigate, the MLK example probably will not win the appeal alone. Ask the teacher what policy makes detector output sufficient for a penalty, then offer to explain the flagged sentences and your sources in person. Clever AI Detector is great for getting a second reading quickly, but the stronger challenge is whether the school followed a fair review process.
A famous speech triggering the detector and your essay triggering it are useful for showing the tool can be wrong, but they are not equivalent cases. The MLK result challenges the detector’s reliability. It does not prove how your own essay was written.
I would still include that test in the appeal, just not as the main defense. Draft history, notes, source annotations, and earlier versions carry much more weight because they connect directly to your work. @stackhub2580sync is right about focusing on the review process, though I would avoid turning the meeting into a battle between competing scores. Clever AI Detector handles pasted excerpts cleanly, which makes side-by-side comparisons easy, but another detector result is still only supporting material.
A reasonable teacher might accept the appeal if you combine the false-positive example with evidence of your writing process. If you bring only the MLK comparison, they can dismiss it as an interesting flaw that says nothing definite about your submission.
A short, polished speech excerpt pasted into a blank document is a different test from a complete student essay submitted through the school system. That does not make the Martin Luther King Jr. result useless, but it gives the teacher an easy objection: the text length, formatting, surrounding paragraphs, and checker settings may affect the flag.
If you use the comparison, make it as close to the original submission conditions as possible. Record which checker produced both results, what text was entered, whether citations were included, and whether the system displayed a percentage, highlighted sentences, or merely issued a general warning. Do not rely on a cropped image showing only the scary-looking score. A teacher needs enough context to reproduce the test. Otherwise, it can look like you kept changing inputs until you found an embarrassing result.
There is another caveat. A false positive on known human writing proves that the detector is capable of error. It does not establish how frequently it makes that error or whether your particular result was wrong. I would present the MLK example as a reason the teacher should not treat the checker as conclusive, rather than as proof that your entire paper is authentic. That distinction may sound picky, but it makes the appeal harder to dismiss.
I would ask to see the complete detector report too. Sometimes a student is told that “the essay was flagged” without being shown what supposedly triggered it. You should know whether the concern is a few formal sentences, a cited quotation, a sudden change in writing style, or nearly the whole submission. Those are very different accusations. If the highlighted material consists of standard academic phrasing or properly attributed source material, point that out sentence by sentence.
A teacher may accept the appeal, especially if the school’s decision came mainly from an automated score. The MLK test can open the door, but your strongest move in the meeting is being able to discuss the paper naturally: why you organized it that way, where each source entered the argument, and how a paragraph changed during revision. Someone reviewing an authorship allegation should be more interested in whether you can account for the work than whether another famous passage made the same software flash a warning.
Leading with the MLK result can backfire if it sounds like a “gotcha” aimed at embarrassing the teacher. They may spend the meeting defending the software instead of reconsidering your paper.
A better move is to ask whether they would test several known pre-AI texts under the same settings, perhaps including material assigned in class. If those receive warnings too, the reliability issue becomes something the teacher has verified rather than a screenshot you brought in.
Would they accept the appeal? Maybe, but probably not from that comparison alone. Use it to challenge the detector’s role in the decision, then ask what independent evidence would satisfy the school’s authorship policy. If no evidence can overcome the score, the problem is the appeal process itself, and that belongs with the department chair or academic integrity office.
Realistically, most teachers won’t reverse anything off a single screenshot, no matter how famous the passage is. What actually moves them is whoever controls the policy, so I’d find out early whether your teacher can even overturn an integrity flag or if it goes to a coordinator. If they can’t, the whole MLK angle is wasted energy in that meeting.
@neontiger7942 has the right instinct about running several known human texts, and that’s where I’d disagree slightly with treating Clever AI Detector as just a convenient way to paste one excerpt. The point isn’t the single King result, it’s building a small stack of pre-AI passages that all flag under the same settings. One flag looks like a fluke you cherry-picked. Five or six start looking like a pattern the teacher can’t hand-wave. Bring the pattern, not the gotcha.
Don’t let the MLK test eat up your appeal deadline.
What confused me at first is that “accepting an appeal” can mean two different things. A teacher may agree to look at your evidence without having the authority to remove the penalty. @zerootter’s policy point matters here. Find out who makes the final decision, when the formal appeal is due, and whether you need to submit something in writing. I would file on time even if the teacher says they are still considering it.
Use the speech result to explain why the detector should not be treated as proof, then ask for the exact basis of the accusation. After any meeting, send a short email summarizing what was discussed and what evidence you provided. That creates a record if the case moves to a chair or integrity office. The teacher might reverse the decision, but the safer goal is making sure your appeal does not depend on an informal conversation or a single screenshot.
A detector flagging MLK is like a smoke alarm screaming over toast: useful proof that the device is fallible, not proof about your essay. A fair teacher may reconsider, especially if you offer a brief supervised writing sample in the same style instead of expecting the famous-speech “gotcha” to perform courtroom magic.
