I’m having trouble figuring out the best way to access Google Drive on my Mac. I’m not sure if I should use the web, the desktop app, or some Finder integration, and I’m confused by Google’s instructions. I’d really appreciate a simple, step‑by‑step explanation so I can reliably open, sync, and manage my Google Drive files directly from macOS without messing anything up.
How I Actually Use Google Drive On My Mac (Without Going Nuts)
So, I’ve bounced between like 5 different “solutions” for getting Google Drive to behave on macOS, and honestly, most of them have annoyed me in one way or another. If you’re on a Mac and just want your Drive files to show up like normal folders, here’s what has worked for me (and what didn’t).
Step 1: The Official Google Drive Way
If you want the straight, basic route:
- Go to Google’s official download page for Drive for desktop.
- Download the macOS version.
- Open the
.dmgfile and drag the app into Applications. - Launch it and sign in with your Google account.
- After that, you’ll get a Google Drive disk or folder in Finder.
At that point you have two main options inside the app:
Stream files
Files are “virtual” until you open them. Saves disk space but you’re relying heavily on your connection. -
Mirror files
Files are stored in the cloud and on your Mac. Faster access, but eats local storage.
Both work, but:
- It loves to run in the background constantly.
- Sync errors can be super vague.
- If you use more than one cloud service (not just Google Drive), things get messy fast.
So yeah, technically it works, but it’s not exactly pleasant.
Step 2: Accessing Drive From Finder Like a “Normal” Folder
If you stick with the official app, your main interaction will be:
- A Google Drive “volume” in Finder’s sidebar.
- A menu bar icon where you can pause sync, see recent activity, or switch accounts.
You can:
- Drag and drop files into that Google Drive folder to upload.
- Right-click to copy, move, or make aliases like normal.
- Use Spotlight to find local copies (but searches are hit or miss with streamed-only files).
This is fine if:
- You only use Google Drive.
- You don’t mind having another Google thing running all the time.
I lasted like that for a while. Then I added Dropbox, OneDrive, some WebDAV storage, and a random SFTP server into the mix, and it got ugly.
When I Got Tired Of Managing 3+ Cloud Apps
This is where I started looking for something that just lets me mount cloud storage like external drives, instead of installing a different sync client for every service.
What I eventually ended up using on my Mac is this app called
CloudMounter.
Think of it like this: instead of having 4 different “Drive” apps each doing their own sync magic, you get one tool that just makes your cloud accounts show up as mounted drives in Finder.
So:
- Google Drive appears like another disk.
- Dropbox, OneDrive, FTP, SFTP, WebDAV, etc. can all do the same.
- You can browse them directly from Finder without syncing everything to your Mac.
For Google Drive specifically, this solved a couple of my personal headaches:
- I didn’t have to dedicate local storage to giant folders I rarely open.
- I could connect multiple Google accounts without weird workarounds.
- It behaved like external storage that just happens to live in the cloud.
You still sign into your Google account, obviously, but after that it’s basically:
open Finder → click the mounted drive → drag files around like they’re on a USB stick.
Why Not Just Stick With Google’s App?
Short version of my experience:
Google Drive’s desktop app is fine if:
- You only use Drive.
- You want full local copies or simple streaming.
- You don’t care too much about having multiple apps for different clouds.
It gets annoying if:
- You have more than one cloud service.
- You hate background apps fighting over your bandwidth.
- You want everything to show up in Finder in a consistent way.
For me, using something like CloudMounter let me treat Google Drive like a network drive instead of a special snowflake app. I still log into my Google account, still see my usual folders, just without another sync client running its own little ecosystem.
Honestly the “right” way depends on how you actually use Drive, not what Google’s docs say.
Here’s how I’d break it down, trying not to just rehash what @mikeappsreviewer already covered.
1. Web only
Use this if:
- You just need to occasionally grab or upload files
- You mostly work in Docs/Sheets in the browser
- You don’t care about Finder at all
- Zero install, zero background processes
- No sync weirdness, no local disk space used
- Super clunky for dragging stuff between Drive and local folders
- No offline access unless you do the weird “Offline” setting in Chrome
- Doesn’t feel like part of your Mac at all
This is the “I don’t really live in Drive” option.
2. Google Drive for desktop (the official app)
Despite some pain points, this is still the default I’d suggest for most single Drive users.
When it actually makes sense:
- You live in Drive every day
- You want to open Finder, see a “Google Drive” thing, and pretend it’s a local folder
- You’re okay with one more background process
The real decision is:
- Stream files if your Mac storage is tight or your Drive is huge
- Mirror files if you want offline access to almost everything and have SSD space
What I disagree with a bit from @mikeappsreviewer:
If you only use one cloud and it’s Google Drive, I actually think their app is the least painful option. It’s opinionated and weird sometimes, but it’s also the one thing that’s guaranteed to be fully supported for everything Google randomly changes next year.
Gotchas:
- It loves to spam your menu bar and run at login
- Sync errors are vague and occasionally stupid
- If you have multiple Google accounts, the UX is… confused at best
3. Finder-style access without full sync
This is where tools like CloudMounter come in handy, and I actually think they’re most useful in your situation if:
- You specifically want Finder integration
- You don’t want to sync gigabytes locally
- You have more than one service (Drive + Dropbox + OneDrive etc.)
CloudMounter basically mounts Google Drive like a network drive:
- Shows up in Finder as a volume
- No huge local mirror
- You drag/drop like a normal folder, but files stay in the cloud
Where I personally prefer CloudMounter over just Drive for desktop:
- Multiple Google accounts are cleaner
- If you’re also on Dropbox/OneDrive/etc, it’s one mental model: “These are all network drives”
- Easier to keep your SSD from filling up with stuff you opened once in 2019
Downsides:
- Third party app between you and your data
- Sometimes slower than a fully synced local folder
- If your internet is flaky, it can feel laggy
What I’d actually recommend for you
Given what you wrote:
If you want simple and don’t care about “best”:
Install Google Drive for desktop, choose Stream files, and call it done.
You’ll see Drive in Finder, it mostly “just works,” and you don’t need to fiddle with anything else. -
If you’re already using other cloud services or hate clutter:
Skip Google’s app and use CloudMounter to mount Google Drive in Finder.
Treat it like a network drive you plug in via Wi‑Fi. -
If you very rarely touch Drive:
Don’t install anything. Use the web, drag files via the browser, and avoid all the background sync drama.
If you say how often you use Drive, whether you have multiple Google accounts, and how big your Drive is, you can narrow it to one of those three pretty easily. Right now you’re stuck in “too many options, zero defaults” land, which is exactly where Google’s instructions leave people.
Short version: how you use Drive matters more than which app is “correct.” Since Google’s docs are kind of a mess, here’s a different angle from what @mikeappsreviewer and @chasseurdetoiles already laid out.
I’d think about it like three usage patterns instead of three apps:
1. “Drive is just a file dump I visit sometimes”
If you:
- Occasionally upload PDFs, exports, photos
- Mostly work in local apps (Word, Preview, etc.)
- Don’t need offline access to cloud stuff all the time
Then honestly, sticking to the web only is totally fine:
- Use drive.google.com in your browser
- Drag files between Finder and the browser window
- Turn on offline in Chrome only if you really need “I’m on a plane” editing
A lot of people try to over-engineer this and end up with 3 sync clients for something they touch once a week. If that’s you, uninstall everything and live in the browser.
2. “Drive is where I live all day”
Here’s where I slightly disagree with both of them: if you actively open and save files all day, the official Google Drive for desktop is not just “fine,” it’s realistically the least headache long‑term.
Use it if:
- You work in Docs/Sheets but also in local apps
- You want to hit Cmd+S in, say, Photoshop and have it save directly into Drive like a normal folder
- You want some level of offline access that isn’t a science project
Tips that make it less annoying:
- During setup, pick Stream files first. If stuff you care about is too slow, right‑click specific folders and mark them for offline. No need to mirror your entire 300 GB of “Random Stuff 2014.”
- In macOS System Settings → Login Items, disable the Drive launcher if you hate auto‑start, and just open it manually when you actually need it.
- In the menu bar icon, turn off useless notifications so it stops nagging you about every tiny sync.
Imo, most of the “Drive is awful” complaints come from people either mirroring everything or using it for 9 accounts at once.
3. “I have several clouds and want Finder integration without chaos”
This is the use case where CloudMounter actually shines and is not just yet another app to babysit:
Use something like CloudMounter if:
- You have Google Drive plus Dropbox, OneDrive, maybe a server somewhere
- You mainly want Finder access, not full sync
- You’re okay with “this behaves like a network drive, not a local folder”
How it’s different from Google Drive for desktop:
- Nothing is really synced locally by default
- All your stuff (Drive, Dropbox, SFTP, WebDAV, etc.) shows up as separate mounted volumes
- You get one mental model: “all of this is external storage,” instead of 3 different sync tools doing who‑knows‑what
Tradeoffs:
- If your connection is slow, opening big files feels like opening from a NAS
- You are trusting a third party to sit between macOS and your data
- Spotlight search on those mounted drives is not as magical as native local folders
Where I think CloudMounter is a legit “best of both worlds” for you:
- You said Finder integration matters, but you’re confused by Google’s way of doing it
- You probably don’t want your SSD eaten by stuff you barely open
- If you ever add another service, you won’t have to learn a brand new sync tool again
How I’d choose in your position
If you tell me nothing else, I’d sort it like this:
You open Drive maybe once or twice a week:
Use the web only. No apps, no background stuff, less clutter. -
You’re in Drive every day, mostly one account, don’t use 3 other clouds:
Install Google Drive for desktop, pick Stream, then mark only key folders offline. -
You have 2+ cloud services or multiple Google accounts and Finder is your main hub:
Use CloudMounter and treat Google Drive like a network disk you mount when needed.
If you share a bit more about how much space your Drive uses and whether you’re juggling multiple accounts, it’s actually pretty easy to say “do X and ignore everything else.” Right now you’re stuck because you’re trying to pick a tool without pinning down your workflow first.
Short version: you are not choosing between “web vs desktop vs Finder,” you are choosing between “sync everything vs treat Drive like a network disk vs barely touch it.”
Since @chasseurdetoiles, @byteguru and @mikeappsreviewer already covered the general options and the basic setup, here are a few angles they did not dig into much.
1. Decide how sticky you want Drive to be
Ask yourself:
- Do you want Drive to feel like part of your Mac, even offline?
- Or are you fine with “I only see stuff when I am online and I open it manually”?
If you want Drive to feel native and are mostly in a single account, Google’s own Drive app is still the most integrated. I actually disagree slightly with the idea that it is only “fine.” For people who live in Finder and Spotlight, its offline mode plus version history is hard to replicate.
If you are nervous about Google’s sync doing its own thing, then you are better off with a “network drive” approach.
2. Where CloudMounter actually fits, beyond what was said
The others already mentioned CloudMounter as a unifying layer. I would frame it like this:
CloudMounter is best when:
- Your main need is “mount, browse, copy” rather than true bidirectional, constant sync.
- You juggle multiple clouds and do not want 3 or 4 separate menu bar clients.
- You are okay treating everything like a server share that can be mounted or unmounted.
Pros of CloudMounter for your scenario:
- Finder integration feels natural, like external disks for each cloud.
- Zero forced full-sync of huge folders, so your SSD does not get eaten.
- Easy to keep work and personal Google accounts side by side.
- One mental model for Google Drive, Dropbox, OneDrive, etc., which reduces confusion compared to multiple vendor apps.
Cons you should be aware of:
- It is not a perfect replacement for true sync. Large files open more like they are on a NAS.
- If your internet is flaky, you will really feel it, because nothing is guaranteed offline.
- Spotlight search on those mounted drives is limited compared with fully local folders.
- It is another piece of third party software that sits between you and your data, which some people in regulated environments are not allowed to use.
- For heavy collaboration with Google Docs, the web interface still wins on features.
So if your goal is “I want Drive to behave predictably in Finder, without me learning every quirk of Google’s app, and I might add Dropbox or others later,” then CloudMounter is a strong candidate.
3. When not to bother with CloudMounter
Here is where I slightly push back on the others:
- If you only have one Drive account
- And you are okay with Drive being “always on”
- And you need serious offline access for specific folders
then adding CloudMounter on top of the official app is just complexity. In that case, you are better off:
- Using the official Drive client with file streaming.
- Mark only a few key folders as “available offline” inside the Drive folder in Finder.
- Ignoring the rest of your archive until you actually need it.
CloudMounter shines as an organizer of multiple services more than as a replacement for the basic “I just want one Drive folder” workflow.
4. Rough recommendation based on common Mac setups
Small internal SSD, multiple cloud services, mostly online:
Use CloudMounter and treat Google Drive like a mounted volume you connect to when you work. -
Big internal SSD, single Drive account, mixed online/offline use:
Use Google’s Drive app with streaming and selective offline folders, skip other tools. -
Light usage, Drive is mainly an archive:
Forget clients. Use the web, maybe keep CloudMounter only if you like the “all clouds as drives” layout.
You are not wrong to be confused by Google’s documentation. Pick the model that matches your habits first, then the tool. If later you add Dropbox or similar, that is the moment when revisiting CloudMounter becomes almost a no brainer.
