Need help creating a custom ringtone on iPhone
I’m trying to set up a custom ringtone on my iPhone but I’m having trouble figuring out the process. I’ve got a song in mind that I want to use, but I’m not sure how to get it to work as a ringtone. Can someone guide me through the steps or recommend an easy method?
Hey there! If you want to set a custom song as your ringtone on your iPhone, it can be a bit tricky, but I got your back. Follow these steps:
Gather Your Tools
  1. First, make sure you have the song saved in your iPhone’s music library. If it’s not there yet, you can use platforms like Apple Music to download it.
  2. Download GarageBand from the App Store if you don’t already have it. It’s essential for this process.
Creating the Ringtone Using GarageBand
  1. Open GarageBand and create a new project. You’ll want to select “Audio Recorder.”
  2. Hit the “Tracks” view button to switch from the audio recorder to the tracks view.
  3. Tap the loops icon (looping circles) and then choose ‘Music’ to find your song.
  4. Drag and drop the song onto the workspace. Note you’ll need to trim it to a maximum of 30 seconds.
Trim the Song
  1. Find the section you want to use as a ringtone. You can drag the edges of the clip to adjust the length. Zoom in for precision.
  2. Listen to your selection to ensure you like how it sounds and make any adjustments.
Export as Ringtone
  1. Tap the down arrow in the top-left corner and select ‘My Songs.’
  2. Tap and hold the thumbnail of your project and then select ‘Share,’ then ‘Ringtone.’
  3. Name your ringtone and press “Export.”
Set Your Ringtone
  1. Go to “Settings” > “Sounds & Haptics” > “Ringtone.”
  2. Your custom ringtone will be listed up top. Select it, and you’re done!
If you run into any snags, the detailed guide within the app can be a lifesaver. Also, I found threads on similar issues at [Product Title] that might help enhance readability and give more tips.
Let me know if you need any more help!
Not sure if yoy need GarageBand for creating ringtones. I mean, yeah, GarageBand works, but it’s kinda overkill for something simple, don’t you think? I’ve used iTunes on my computer for this. Much easier and doesn’t involve downloading extra apps.
Here’s a different angle using iTunes:
1. Select and Trim the Song
  1. Open iTunes and add the song you want.
  2. Right-click and select ‘Get Info.’
  3. Go to the ‘Options’ tab and set the start and stop times (30 sec max).
2. Convert to AAC
  1. Go back and right-click on the song again.
  2. Choose ‘Create AAC Version.’ This will create a new file with that specific length.
3. Rename the Extension
  1. Find the AAC file (usually ends in .m4a) in your library.
  2. Drag it out of iTunes and onto your desktop.
  3. Change the file extension from .m4a to .m4r.
4. Add to iPhone
  1. Connect your iPhone and open iTunes.
  2. Drag your .m4r file into the ‘Tones’ section of your device (in iTunes).
Then just set it up as a ringtone from the settings on your iPhone. Easy peasy. GarageBand’s cool but iTunes is less hassle for this sort of thing.
If you still prefer using an app and need more details, check out [Product Title] for more tips. Seriously, loads of info there.
Use a web ringtone site so you avoid iTunes and GarageBand.
  1. On your iPhone, open Safari.
  2. Go to mp3cut.net or mp3cutter.com.
  3. Upload your song, trim 20–30 seconds, export as m4r if offered, mp3 if not.
  4. Download the file, then share it to the “Ringtones: Maker” or “Ringtones for iPhone!” app from the App Store.
  5. Follow the app steps to install via a config profile in Settings.
You get the ringtone with fewer steps and no computer.
