I recently started using Rork Ai but I’m confused about how to get the best results from it. Some features don’t behave as I expect, and the documentation feels unclear or incomplete. Can someone explain practical tips, best settings, or common mistakes to avoid with Rork Ai so I can actually make it work for real projects?
Short version. Rork Ai behaves best when you treat it like a picky co worker, not a mind reader. Here is what tends to work.
- Be stupid specific in your prompt
- State role: “You are a senior backend dev focusing on Python APIs.”
- State goal: “I want a migration plan from X to Y.”
- State format: “Return a table with columns: Step, Owner, Risk, Example.”
- Give context: code snippets, error logs, sample data, business rules.
Bad: “Help with my project.”
Better: “I have a FastAPI service with this route: . I get 500 on POST. Here is the traceback. Explain what is wrong and give a patched version.”
- Ask for structure
Rork Ai tends to ramble if you do not pin it down.
Tell it things like:
- “Limit answer to 10 bullet points.”
- “No intro text. Go straight to steps.”
- “Keep code under 60 lines and include comments.”
If it ignores format, reply:
“Re answer using the format I asked. No extra text.”
It usually snaps back in line.
- Use short, focused chats
New chat for each distinct task.
One for brainstorming features.
Another for writing test cases.
Another for debugging.
Long tangled threads confuse it. Context gets weird, you get off answers.
When it starts hallucinating stuff you never said, start a new thread and restate the key facts.
- Iterate instead of asking for perfection
Do small loops.
- First: “List 5 approaches.”
- Then: “Pick approach 2. Give high level steps.”
- Then: “Detail step 1 with code and tests.”
This beats “Write the perfect implementation for my whole app.”
You keep control, the model does less guessing.
- Paste real artifacts
Paste:
- Exact error messages.
- Config files.
- Small but complete code examples that reproduce the issue.
Say “Here is minimal repro” then provide one file or function.
You get more accurate help than with partial, hand waved descriptions.
Use examples to steer tone and style
If the output style feels off, give a sample.
“Write it like this example below” then paste 1 short sample of how you want it to sound.
Mention: length, tone, headings, code fences, or no code fences, etc.
Ask it to self check
Before trusting output, tell it to verify.
- “First, list assumptions you are making.”
- “Then, compare your solution against requirements and list mismatches.”
- “Point out any risky parts or edge cases.”
This exposes wrong guesses and missing constraints.
- For features that feel weird
If something behaves oddly, try these quick tests.
- New chat with a stripped down version of your question.
- Ask “Repeat my instructions in your own words” to see what it understood.
- Ask “What information is missing from my request” to see gaps.
If behavior still feels off, the feature is either buggy or poorly documented. Work around it with manual instructions.
- Use it as a helper, not as source of truth
For code, text, or analysis.
- Run the code.
- Compare against docs or specs.
- Ask follow up questions.
Treat outputs as drafts.
You do review, it does the grunt work.
- Simple template you can reuse
You can start most Rork prompts like this and adjust:
Role: “You are a [role].”
Goal: “My goal is [one clear outcome].”
Context: “Here is the context: [paste].”
Output: “Give [type of output] with [constraints: length, format, style]. No extra commentary.”
If you post a sample prompt you tried and the reply you got, people here can help tighten it.
I’ll disagree a tiny bit with @suenodelbosque on one thing: you don’t always need super rigid prompts. Rork Ai can still be useful for fuzzy, early-stage thinking, as long as you set guardrails in a different way.
Here are some practical angles that complement what’s already been said:
Use “sessions” with a stable persona
Instead of rewriting the full role every time, do this in a fresh chat:- “For this whole conversation, act as a senior X who optimizes for Y. When I’m unclear, ask clarifying questions instead of guessing.”
Then in followups you can be shorter: - “Using the same assumptions, help me refactor this function: …”
This balances detail with not rewriting a novel each prompt.
Force it to ask questions first
When features feel unpredictable, flip the script:- “Before answering, ask up to 5 questions that would help you give a better answer. Do not propose a solution until I respond.”
That stops it from confidently sprinting in the wrong direction.
Deal with “weird features” by sandboxing them
If some Rork feature is confusing (like a special mode, plugin, tool, etc.):- Make a separate chat just to poke it: “I’m testing ONLY the X feature. Explain what you can and cannot do in this mode. Give 3 examples you won’t handle well.”
- Then try very small tasks with it, compare with normal responses.
Treat the feature like a beta experiment, not core workflow, until you understand its quirks.
Use “diff” style for code changes
When code edits keep coming back bloated or inconsistent:- “Show only a unified diff against my code. Do NOT rewrite the whole file. Use
diffformat.”
That massively reduces random changes and makes it obvious what it touched.
Constrain “creativity” explicitly
If it keeps hallucinating or making stuff up:- “If you are not at least 80% sure about a fact, say ‘I’m not sure’ and suggest how I can verify it.”
- “Prefer saying ‘I don’t know’ over guessing.”
This makes it act more like a cautious junior dev than a storyteller.
Make it track decisions
For longer tasks, context drift is a killer. One workaround:- “Keep a running ‘project log’ in bullet points at the end of each answer: what we decided, what we rejected, and open questions.”
- Later you can say: “Summarize the project log into a short brief” to reset or start a clean chat with that summary.
This compensates a bit for weird context behavior.
Use “A/B answers” when you’re unsure what you want
If you’re not even sure what kind of output would help:- “Give me 2 alternative answers:
A) Short & highly practical
B) Longer, with explanations of tradeoffs.”
Then you can say “Stick with style A in this chat from now on.”
Handle unclear docs with meta-questions
When documentation is garbage or incomplete:- Paste the doc chunk and ask: “Summarize what this actually lets me do, then list 5 questions you would ask the product team about gaps or edge cases.”
- Then: “Given those gaps, suggest a safe way to use this feature without relying on undocumented behavior.”
This gets you a “safe default usage pattern” instead of you trusting half-baked docs.
Turn it into a test harness for its own output
Especially for code and configs:- “Write the solution, then immediately write tests or validation steps that would prove it works. If you can’t think of good tests, say so.”
The tests will often reveal where its own logic is fuzzy, and you can push on those points.
When it keeps ignoring you, go adversarial
If it repeatedly drops a requirement:
- “List every explicit constraint from my last prompt. Then state how your answer satisfies each one, line by line. If it does not, fix it.”
That usually snaps it out of the “polite essay” mode and into checklist mode.
Last thing: don’t be afraid to just tell it “Stop giving me generic advice, I already know X, Y, Z. Focus only on A and B.” Rork Ai actually responds pretty well to being called out when it’s being hand-wavy, as long as you’re specific about what you don’t want.
Quick FAQ-style breakdown, building on what @boswandelaar and @suenodelbosque already covered, but from a slightly different angle.
Q1: How do I figure out what Rork Ai is actually good at for my workflow?
Instead of starting from “what can Rork Ai do,” start from your tasks:
- List 5 recurring things you do weekly:
Examples: “summarize long specs,” “sketch API designs,” “draft email responses,” “write test outlines.” - For each, ask: “What part is boring / repeatable / rules-based?”
- Feed only that slice to Rork Ai.
- “Here is a spec. Your only job is to extract: inputs, outputs, invariants, edge cases. No narrative.”
This avoids the trap of using it as a magic all-in-one and focuses on repeatable leverage.
Q2: How do I stop it from being overconfident or fluffy?
Instead of just tightening prompts, adjust incentives:
- Add a “penalty clause” in your prompt:
- “You lose points if you guess. Prefer ‘I don’t know’ over speculation.”
- “You must give at least 3 reasons why your answer might be wrong.”
- Ask for contrasts:
- “Give the solution, then immediately describe a plausible alternative and when it would be better.”
This tends to reduce confident nonsense because it is explicitly asked to surface doubt.
Q3: How do I debug when Rork Ai gives inconsistent answers?
Treat it like debugging a flaky test:
Stability check
- Ask the same question in a new chat, copy paste verbatim.
- If answers differ a lot, say:
- “Explain why your answer here differs from the previous one. Which is safer to trust and why?”
Input shrink
- Remove half your context and ask again.
- Keep shrinking until you find which piece of context is steering it weirdly.
- Often a single ambiguous sentence is confusing it.
Spec lock
- Once you get a good answer, respond:
- “Treat this answer as the spec for the rest of the chat. Do not contradict it unless you explicitly say you are revising it and why.”
Q4: Any way to make Rork Ai help with “unknown unknowns”?
Yes, but you need to ask for coverage, not just solutions:
- “Given the problem description, list 10 categories of things that could go wrong: performance, security, data quality, UX, legal, etc. Mark which categories you are least confident about.”
- “From those categories, pick the top 3 riskier ones and ask me 3 questions each.”
That way, instead of pretending it knows everything, it becomes a risk radar.
Q5: How can I systematically evaluate if Rork Ai is worth using on a task?
Do a tiny time/quality experiment:
- Pick a normal task you do (e.g., draft incident postmortem).
- Do it once without Rork Ai. Time it and rate quality 1–10.
- Next week, do the same kind of task with a clear prompt structure like:
- “You are a postmortem writer. Input: incident notes below. Output: a draft with sections: Summary, Impact, Timeline, Root cause, Fix, Follow up items. Max 800 words.”
- Compare:
- Time saved
- Edits needed
- Did it miss anything critical?
Do this for 3–4 task types. You will quickly see where Rork Ai shines and where it just burns review time.
Q6: How do I get better at prompting without memorizing 100 tricks?
Create your own tiny “prompt checklist” template, something like:
- What is the decision or artifact I want at the end?
- What are the hard constraints? (length, format, tools, stack, audience)
- What is the source of truth? (spec, codebase, company rules)
- What failure mode do I fear most? (hallucinations, verbosity, missing edge cases)
- One explicit “don’t”:
- “Do not invent APIs not in the docs below.”
Paste that as a skeleton and fill it in; it becomes muscle memory.
Q7: Pros & cons of using Rork Ai this way
- Very good at mechanical tasks: restructuring content, generating variants, drafting boilerplate.
- Great for “second brain” tasks: listing risks, assumptions, checklists.
- Can speed up exploration when you explicitly ask for alternatives and tradeoffs.
- Reduces context switching for you: summarizing meetings, specs, pull requests.
- Still prone to confident errors, especially with niche tech or fuzzy specs.
- Can waste time if you use it for tasks that need real domain judgment instead of grunt work.
- Long, entangled chats drift in quality unless you keep resetting or summarizing.
- Requires you to be explicit about uncertainty; otherwise it defaults to sounding sure.
Q8: How does this compare with how @boswandelaar and @suenodelbosque use it?
- They lean heavily on tight roles, structure, and short iterative loops, which is excellent for engineering-style problems.
- What I am adding here is more meta-usage: treating Rork Ai like a system you can test, benchmark, and critique, instead of just a fancy autocomplete.
- You might even combine approaches: use their structured prompts, then layer on the “penalty clauses,” stability checks, and mini time experiments from this post.
If you share one specific Rork Ai reply that felt off to you (with your original prompt), people can help you build a checklist-style prompt around it so you can reuse that pattern across many tasks.
You covered task slicing, penalty prompts, stability checks, input shrink, spec locks, risk coverage, time trials, and a prompt checklist. Solid.
Simpler path, Golden Example method. Pick one output you like. Paste it as the refernce. Say, Mirror this structure and tone. Input below. Ask for sections A, B, C, with word caps. Set a 5 minute timer and 2 revision cap. Score each draft 1 to 10 on fit to teh example. If score stays under 7, stop and switch. Save the prompt as a text snippet to reuse. Example use, status email, incident postmortem, code review notes.
