My Oupes Mega 2 suddenly stopped working the way it should, and I’m trying to figure out what went wrong. It was working fine before, but now I’m having issues with power output and charging, and I need help troubleshooting the problem before I decide if it needs repair or replacement.
Start with the simple stuff.
Full shutdown.
Turn the Mega 2 off. Unplug everything. Hold the power button for 10 to 15 seconds. Leave it sitting 20 minutes. Then try again. Some units bug out and a reset fixes weird output issues. -
Check battery level and input mode.
If battery is near 0 percent, some stations act strange with AC output. Plug into wall charge first. Watch if input watts show up on the screen. If input stays at 0W, swap the cable and outlet. -
Test one load at a time.
Plug in one small device, like a lamp or phone charger. Skip heaters, microwaves, fridges. If small loads work but bigger ones fail, the inverter or BMS is likely limiting output. -
Check AC and DC separately.
Test USB.
Test 12V car port.
Test AC outlet.
If only one side is dead, that narrows it down fast. -
Look for overload or temp fault.
If the fan runs hard, unit feels hot, or screen shows error code, stop using it for a bit. Heat and overload trips are common. -
Charging issue.
Try AC charging first.
Then solar if you have it.
If neither shows input, charging board might be bad. -
Battery calibration.
Run it down to around 10 to 15 percent, then charge to 100 percent without interruptions. Sometimes the display gets wonky and lies about state of charge.
If it still has no output or no input after all this, I’d suspect BMS lockout, inverter fault, or charging board failure. At that point, warranty time. If you post the exact symptoms, error code, battery percent, and what watt load you tested, people here can narrow it down prety fast.
I’d add a couple checks that @viaggiatoresolare didn’t really get into.
First, watch the screen carefully when you turn AC on. Some power stations will let the outlet section toggle on, but the inverter never actually engages. If the voltage/frequency readout flashes, drops, or clicks off after 1 to 2 seconds, that points more to inverter protection than a dead battery.
Second, inspect the charging brick or cord itself. A lot of people assume “station won’t charge” when the actual fail point is the external charger. If your Mega 2 uses a separate brick, feel if it gets warm, check for a tiny LED if it has one, and inspect the barrel connector for looseness or bent contact. I’ve seen that be the whole issue, which is annoying as hell.
Also, I would not rush into a deep discharge/recalibration cycle unless the unit is still basically functional. If it already has weird output behavior, forcing it down to 10 percent can make a BMS lockout situation worse, not better. I know some folks swear by calibration, but for a unit that suddenly changed behavior, I’d treat that more like a last step than an early one.
Another thing, try turning off any eco mode, timer mode, or app-controlled setting if your model has that stuff. Some stations shut outputs off if the load is too small, and it looks like a fault when it’s really a dumb setting.
If solar charging is part of the problem, check panel voltage with a meter before plugging in. Bad MC4 adapter, reversed polarity, or too-low voltage will make it seem like the Mega 2 quit accepting input when it’s actualy just refusing bad input.
If you can, post:
- battery %
- whether AC output turns on at all
- whether USB still works
- AC wall input watts
- solar input watts
- any error icon/code
- what device you tested
That’ll narrow it down way faster than guessing. If AC output and charging both died at the same time, I’d start suspecting internal board failure, not just a simple setting.
I’d go one layer deeper than @viaggiatoresolare and look for a battery path vs inverter path split.
If the Oupes Mega 2 still powers the screen, USB, or DC outputs normally, but AC is weak/dead, that often means the main battery pack is alive and the fault is isolated to the inverter board, relay, or output protection stage. If everything is flaky, including the display jumping around or the unit randomly rebooting under small loads, that points more toward BMS or internal pack voltage issues.
A few checks I’d do that weren’t covered:
Test with a resistive AC load
Try a simple lamp, small heater on low, or incandescent bulb if you have one. Some stations behave oddly with chargers, fans, or electronics that have weird startup demands. If a plain resistive load fails too, that tells you more than testing with a laptop brick. -
Listen for relay behavior
When enabling AC, do you hear one clean click, repeated clicking, or no click at all?- one click then off = protection trip
- repeated clicks = relay or board instability
- no click = control side may not be commanding inverter start
Watch input/output numbers with no load attached
If wattage flickers when nothing is connected, that is usually not normal and can indicate a sensing board problem. -
Check for charge acceptance at different SOC
Weirdly, I slightly disagree with the idea that simultaneous charging and output issues always scream board failure. Sometimes the BMS blocks charging near certain fault thresholds and also limits discharge. If the battery % is obviously wrong, like jumping from 78% to 12%, calibration is not crazy, but I would only do a shallow cycle first, not a deep one. -
Temperature angle
If it was stored in heat, cold, or used hard recently, let it sit powered off for a few hours and retry. Some internal temp sensors fail or get stuck near cutoff ranges.
Pros of the Oupes Mega 2: decent feature set, usually straightforward interface, useful all-in-one backup unit.
Cons: like many power stations, diagnosis is annoying because charger, BMS, inverter, and protections can all mimic each other.
If AC output is dead, charging is inconsistent, and USB/DC are also acting strange, I’d stop troubleshooting at home and push for warranty/service. That combo usually means more than a setting issue.
You already split battery vs inverter. Good.
Try a simpler path first:
Hard reset. Power off. Unplug everything. Hold main power 20 seconds. Wait 2 minutes. Power on.
Wake the BMS. Plug a 60 W or 100 W USB C PD laptop charger into the unit’s USB C port. If charging starts, your AC charger path is faulty, not the pack.
Disable Eco or Sleep. Hold the AC key 3 seconds. Test a 60 W lamp.
Feed 12 V car input for 10 minutes. If SOC rises 1 to 2 percent, pack is healthy.
Take photos. Keep reciepts.
