NetSpot vs Ekahau for WiFi site surveys—what should I choose?
I’m planning a detailed WiFi site survey for an office space and I’m stuck choosing between NetSpot and Ekahau. I need reliable heatmaps, interference analysis, and planning tools, but my budget is limited and I’m not sure which one gives the best value for professional use. Can anyone with real-world experience compare NetSpot WiFi mapping and Ekahau for accuracy, features, learning curve, and long-term use so I don’t make an expensive mistake?
I bounced between Ekahau and NetSpot for a while for Wi-Fi surveys, so here is what I ended up sticking with and why.
Ekahau first. It does a ton. Proper enterprise feature set, lots of knobs, lots of views, planning tools for people rolling out networks in stadiums, hospitals, airports, that sort of thing. When I trialed it, I spent more time learning the workflow than fixing any Wi-Fi. It felt like using a full CAD suite to hang a picture in the hallway. Also the price tag made my manager squint and close the tab.
Then I tried NetSpot from here:
Different vibe. I opened it and started walking around with my laptop in ten minutes. No “read the manual first” moment. For what I needed, it covered the basics:
• Heatmaps that made sense at a glance
• Signal strength and noise readings tied to the floor plan
• Quick check for dead zones and overlapping channels
• Enough detail to explain issues to non-IT people
Use case on my side:
Small offices, a few warehouses, and my own home setup where I run multiple APs and separate SSIDs for work gear, IoT stuff, and guest traffic. Nothing like a university campus. For those smaller jobs, NetSpot hit the right balance. I walked a site, exported a map, and the client understood why the far corner office had trash Wi-Fi.
Concrete example. One office had “random disconnects” near the meeting room. With NetSpot, I walked the area, and the heatmap plus channel view showed three APs stacked on the same 2.4 GHz channel, plus a neighbor’s router bleeding in from the next office. I shifted the internal APs to saner channels, added one extra AP closer to the meeting room, then walked again. The before/after maps made the fix obvious, and nobody argued about the extra hardware.
With Ekahau, I suspect you get deeper modeling, fancier planning, better alignment with big corporate processes. If you manage hundreds of APs across multiple buildings and need predictive design before anything gets mounted, Ekahau has tools for that. I never reached a point in small jobs where NetSpot felt like the bottleneck.
What I liked in NetSpot on a day to day basis:
• Install, load a floor plan, start walking, done
• Runs fine on a regular laptop, no special rig
• Good enough export options to drop into tickets or reports
• Short learning curve if you hand it to another tech on your team
Where it feels weaker:
• Big multi-floor predictive planning is not its strongest side
• Reporting is simpler, which is fine for SMBs, less fine if your boss wants 40-page PDFs every week
If you do Wi-Fi work for homes, small offices, or a single building with a handful of APs, NetSpot makes more sense in terms of time and money. If you handle airports or huge campuses and need advanced modeling, you probably bite the bullet and pay for Ekahau.
There is a decent walkthrough here if you want to see NetSpot in action before touching it:
If your budget is tight and this is “one office, not a campus”, I’d lean NetSpot App, but with a few caveats.
Quick comparison for your use case.
Budget
Ekahau: High license cost, plus they push the Sidekick hardware. Great hardware, painful on budget.
NetSpot App: One of the cheapest ways to get decent heatmaps and surveys. For a small office, cost per project stays low.
Heatmaps and survey workflow
Ekahau: Excellent accuracy, more survey modes, better for dense AP environments. But you spend time learning it. If you do WiFi work all week, that time pays off.
NetSpot App: Import floor plan, set scale, walk. For an office with, say, 5 to 20 APs, it will show you signal coverage, SNR, and dead spots clearly enough to make decisions. I agree with @mikeappsreviewer here.
Interference and channel analysis
This is where I slightly disagree with @mikeappsreviewer.
If you need deep interference analysis from non WiFi sources like microwave leakage, DECT phones, Bluetooth floods, you benefit from Ekahau with proper spectrum hardware. It gives cleaner visibility into non 802.11 noise.
NetSpot App is fine for channel overlap, co channel congestion, and quick validation. For neighbor AP bleed and bad channel planning, it is enough.
Planning tools
Ekahau: Strong predictive design, wall material libraries, multi floor modeling, capacity planning for high client density. If you are planning multiple refreshes, roaming optimization, and want to simulate “what if we move this AP three meters and change antenna”, Ekahau wins.
NetSpot App: Usable planning, but simpler. Good if you are planning a few AP adds or repositioning in a single office. If you need strict SLAs or must justify every AP to upper management with detailed reports, Ekahau reports look better.
When I would pick NetSpot App
• One or two floors, under ~25 APs.
• Budget is limited.
• You need clear heatmaps, channel layout, and before or after screenshots for clients or managers.
• You do not need hardcore predictive design, you are mostly fixing coverage and channel issues.
When I would swallow the Ekahau cost
• Multi floor office with roaming complaints.
• Many APs per floor, higher density, voice over WiFi, or warehouse with scanners where coverage gaps are expensive.
• You expect to do lots of projects over the next 2 to 3 years, so you amortize the license.
Practical suggestion
Start with NetSpot App for this office.
Do:
  1. One passive survey per SSID band, 2.4 and 5 GHz.
  2. Check RSSI, SNR, and channel overlap.
  3. Adjust channels and power, add APs only where heatmaps show real gaps.
  4. Re survey to confirm.
If after this you still see unexplained issues, especially latency or roaming drops with good RSSI and SNR, then revisit Ekahau or a short term Ekahau engagement rather than buying it outright.
For your described needs, NetSpot App hits the budget and feature balance better. Ekahau starts to shine once you manage multiple sites or treat WiFi design as your main job, not a side task.
If your budget is tight and this is “just” an office and not a campus, you’re already leaning away from Ekahau even if you don’t know it yet.
I mostly agree with @mikeappsreviewer and @himmelsjager, but I don’t think the choice is purely “small = NetSpot, big = Ekahau.” It depends more on what problem you’re actually solving.
You said:
  • Need reliable heatmaps
  • Need interference analysis
  • Need planning tools
  • Budget is limited
  • Single office
Here’s how I’d slice it for that scenario:
1. Heatmaps & basic survey
Both products will give you “good enough” heatmaps for a typical office. For walking a floor with 5–30 APs and figuring out:
  • Where coverage drops
  • Where RSSI is trash
  • Where SNR is low
  • Where you’ve got channel overlap
Netspot App is easily sufficient and way cheaper. This is where I diverge a bit from the “Ekahau is more accurate” crowd. In a normal office with drywall, cubicles, and glass, the limiting factor is almost never the fine‑grained modeling. It’s bad AP placement and bad channel/power planning, which Netspot App exposes just fine.
2. Interference analysis
This is the one spot where I’d push back slightly on both of them.
If by “interference analysis” you mean:
  • Co‑channel interference
  • Overlapping channels
  • Neighbor AP bleed
Then Netspot App gets you there with less pain and cost.
If you truly mean:
  • Non WiFi interference (microwave, DECT, rogue RF junk)
  • Detailed spectrum plots
  • Wideband noise hunting
Then yeah, Ekahau plus their hardware is better. But here’s the rub: in a normal office, you usually do not need to own that level of tooling. Renting a spectrum analyzer for a tricky job or hiring a consultant with Ekahau + Sidekick for a day is often smarter than buying the full stack when you’ll use 20% of its power 2 times a year.
So for your current project, I’d not jump to Ekahau just for “maybe there’s weird interference.”
3. Planning tools
This is where Ekahau really pulls ahead in features, but that doesn’t automatically make it the right call for you.
Ekahau shines when:
  • You are doing predictive design before any APs are mounted
  • You care about capacity planning for hundreds of clients
  • You need clean multi floor modeling with attenuation profiles
  • WiFi engineering is your core job, not a side task
Netspot App has planning, but it is more practical than “perfect.” You drop APs on a map, define wall types at a simpler level, and you get a very usable visual of expected coverage. For a single office with a limited budget, this is usually exactly what you need: enough to justify “we should add two APs and move this one.”
Honestly, I’ve seen Ekahau used to produce gorgeous, 40 page designs for offices where the actual problem was “the ISP router is under a metal desk in the finance office.” Right tool, wrong problem.
4. Budget vs future work
One thing the others didn’t really stress: what is your horizon?
  • If this is a one off or once‑in‑a‑while thing, Ekahau is financial overkill.
  • If your role is about to turn into “I design WiFi all the time for multiple sites,” then biting the bullet on Ekahau starts to make sense, because you’ll reuse that workflow over and over.
If you’re not living in the WiFi design world day to day, Netspot App is a better match for how your time and money are actually spent.
5. When I would not recommend Ekahau even if money allowed it
This is where I’ll disagree a bit more:
  • Single building, 1–3 floors
  • Under ~30 APs
  • Main complaints are “dead spots,” “slow in X area,” or “random disconnects”
  • You are not trying to guarantee rock solid voice over WiFi for hundreds of handsets
In that case, the extra power of Ekahau is often just noise. You end up spending brain cycles on attenuation tweaks instead of doing the basic fixes: AP placement, channels, power levels, maybe a couple more APs.
6. So, for your exact case
Based on what you wrote and the constraints you mentioned but didn’t finish typing:
  • Limited budget
  • Single office
  • Need good heatmaps and reasonable interference and planning
Netspot App is the sane choice. You get:
  • Clear, client friendly heatmaps
  • Enough interference visibility for most office situations
  • Simple but effective planning for AP adds and moves
  • A much shorter learning curve so you actually finish the survey instead of learning a new ecosystem
If, after doing a proper survey with Netspot App and fixing the obvious stuff, you still see issues like:
  • Solid RSSI and SNR but constant roaming drops
  • Strange latency spikes in a very controlled RF environment
  • Voice WiFi that fails in very specific micro‑locations
Then you revisit Ekahau or bring in someone with that toolset for a diagnostic engagement instead of buying it outright.
For right now, for this office, bite-sized budget, and what you’ve described, I’d go with Netspot App and put the saved money into better APs or an extra AP where your heatmaps show genuine pain.
If your office is a single site and the budget already hurts, you are almost certainly in “Netspot App + good APs” territory, not “Ekahau + Sidekick + yearly maintenance.”
Quick angle that complements what @himmelsjager, @sognonotturno and @mikeappsreviewer already covered:
How I’d choose, given your constraints
Think in terms of risk rather than just features:
  • Risk you overbuy with Ekahau
    You get world class predictive design, detailed spectrum integration and reporting that would make a hospital IT team happy. In a regular office, most of that sits idle. Your actual problems are usually: bad AP placement, bad channels, misconfigured power, maybe cheap client radios. You do not need a CAD-grade RF model to fix “AP in a metal cabinet.”
  • Risk you underbuy with Netspot App
    You might hit limits if:
    • You need multi floor capacity planning for dense voice or WiFi-first phones
    • You must do repeatable, formal surveys for audits and strict SLAs
    • You want tight integration with vendor ecosystems and hardware analyzers
For a one-office survey, the second risk is usually acceptable.
Netspot App: pros & cons in your use case
  • Very fast to start: import floor plan, walk, click. No full-day learning curve.
  • Heatmaps are more than good enough to:
    • Prove to management where coverage is weak
    • Show overlapping channels and obvious interference from neighbors
  • Runs on a normal laptop, so you do not need special survey gear to get value.
  • Planning mode is “simple but useful”: you can rough in extra APs and see if you are fixing glaring holes without getting lost in RF theory.
  • Cheap enough that you can justify it even if you only redo surveys once or twice a year.
  • Predictive design is not in the same league as Ekahau. If you are trying to design a dense VoIP rollout before cabling is pulled, this will feel shallow.
  • Reporting is functional, not “consulting firm glossy.” If your boss wants 30 page PDFs with every RF metric broken out, you will be doing some manual polishing.
  • Non WiFi interference analysis is limited. If you suspect serious spectrum pollution, you would still want to rent or borrow a dedicated analyzer or bring in someone with Ekahau hardware for a one off job.
Where I slightly disagree with others
I do not fully buy into the idea that Ekahau is “only for huge sites.” Even a mid-sized office can justify it if:
  • WiFi is business critical (voice, scanners, RTLS, etc.)
  • You are standardizing designs across many similar offices
  • You will reuse models and templates over and over
But you did say “budget is limited” and “single office.” In that scenario, Ekahau’s extra accuracy and modeling rarely translate into proportionally better outcomes. You fix 80 to 90 percent of issues with:
  1. A competent survey tool like Netspot App
  2. Sensible AP placement and channel planning
  3. Possibly one or two additional APs where the heatmaps show real pain
If after that the WiFi is still misbehaving in weird ways, that is when you either bring in someone who lives in Ekahau or rent higher end tools for a specific troubleshooting day.
Practical recommendation
  • Use Netspot App for this project.
  • Spend saved budget on:
    • At least one additional AP in obvious dead or weak zones
    • Better mounting and cabling for existing APs
    • Maybe upgrading any truly ancient APs or client devices
Ekahau is fantastic, but for a single budget constrained office you are more likely to get better WiFi by buying “more and better AP” plus Netspot App, instead of “perfect design tool” and no budget left for hardware changes.
Alternative, simpler path:
Skip NetSpot and Ekahau. Do an AP on a stick with free tools. Mount one AP on a tripod with PoE. Print your floor plan, draw a 5 by 5 meter grid. At each point, log RSSI and SNR with WiFiman or AirPort Utility. Run iperf3 to a wired server. Target RSSI -65 dBm or better, SNR 25 dB or better, throughput 100 Mbps. Set 2.4 GHz to 20 MHz, 5 GHz to 40 or 80 depending load. Tweak height and power, re test. This nails placement without licenses. Save budget for teh extra AP.
