What are the exact dimensions of an iPhone 12?
I’m trying to find the exact measurements for the iPhone 12 model, as I need to buy a case or accessories that fit perfectly. Can someone share the length, width, or specifications?
The iPhone 12’s got some sleek and precise dimensions—Size-wise, you’re looking at a length of 5.78 inches (146.7 mm), a width of 2.82 inches (71.5 mm), and a thickness of 0.29 inches (7.4 mm). Weight? It’s 164 grams (5.78 ounces), so not exactly a paperweight but def feels good in your hand without being a brick. If you’re hunting for a case or accessories, like screen protectors or mounts, make doubly sure you’re not confusing it with the 12 Mini or Pro. Those measurements are probs floating around all over search results, so they can trip people up. Been there. Anyway, get a case with a bit of wiggle room or exactly these specs, and you’re golden.
Okay, here’s the thing about the iPhone 12 dimensions—first of all, @cazadordeestrellas nailed the specs, but let me add a bit of texture here. The length is 5.78 inches (146.7 mm), width is 2.82 inches (71.5 mm), and thickness is 0.29 inches (7.4 mm). Sure, those measurements are accurate, but here’s the kicker: cases and accessories are NOT all made equal. Often, cases are labeled as “compatible” with multiple models, and while they technically fit, they don’t always hug the phone as they should. For example, some cases might feel looser when they’re trying to accommodate the iPhone 12 and 12 Pro. Ugh, annoying, right?
Also, word to the wise: don’t assume that just because a screen protector says “iPhone 12” it’ll be perfect. I’ve gotten ones that leave weird gaps by the edges because manufacturers sometimes cut corners. Basically, be cautious and double-check the product reviews—and keep in mind that the iPhone 12 has flat edges, so if someone’s saying a case tugged awkwardly at those edges, it’s probably a no-go.
Oh, and fun fact: despite being 164 grams (5.78 oz), it still manages to feel balanced. Not feather-light like you’re going to drop it, but also not so heavy you feel like you’re curling weights. Honestly, phones these days feel more engineered than some rockets.
Final bit—don’t fall for marketing traps trying to trick you into buying “universal” accessories for the 12 and its siblings because precision matters here. It’s not the Mini, it’s not the Pro. Double, triple-check compatibility. Otherwise, enjoy the joyride of realizing that slick design comes with the stress of finding cases that’ll actually snap on perfectly without nudging the side buttons every time.
Alright, let’s cut to the details and avoid any fluff: the exact dimensions of the iPhone 12 are 5.78 inches (146.7 mm) in height, 2.82 inches (71.5 mm) in width, and 0.29 inches (7.4 mm) thick. It weighs in at 164 grams (5.78 oz). These specs are spot-on, so if you’re after a case or screen protector, keep these numbers locked in your head.
Now, about cases and accessories. Both @nachtdromer and @cazadordeestrellas make solid points, but here’s where I’ll diverge slightly. While they mention cases feeling loose or ill-fitting when labeled for multiple models, I’ve found that premium case brands often nail compatibility down to the millimeter for specific models. So, no—don’t pass up a dual-compatible case just because it’s marketed for both 12 and 12 Pro. Just make sure it specifically includes ‘iPhone 12’ in its list and watch for materials that grip and don’t stretch over time (e.g., silicone doesn’t always age gracefully, y’know?).
Pros of precision cases/accessories for the iPhone 12:
  • Flat edges of the iPhone make cases easier to snap on snugly compared to rounded designs.
  • Exact-fit screen protectors prevent those annoying edge gaps mentioned earlier.
  • The market’s flooded with options given the iPhone 12’s popularity, increasing your odds of finding good deals.
Cons to keep in mind:
  • As someone who loves options, oversaturation is a downside—poor-quality cases sneak in under the radar.
  • Some cut-rate ‘universal’ screen protectors will have coverage issues, particularly on the rounded corners of the display (ugh, why do I always learn this the hard way?).
  • Heftier cases might mask the 164g balance of the phone, making the experience bulky.
Competitor side note: There’s a bit of overlap in points above, like @cazadordeestrellas rightly said about some accessories not ‘hugging’ the phone properly. However, retailers or brands pushing subpar universal cases can turn this model-specific clarity into an unnecessary treasure hunt.
Lastly, flexible plastic cases (TPU) vs. harder plastic (PC)? Pick based on your lifestyle. TPU’s better for drop resistance, especially for the iPhone 12’s flat edges. But it can warp quicker. For accessories? Triple-check reviews, no shortcuts.
If nothing else, thank Apple’s engineering marvel for gifting us a flat-edged phone that doesn’t roll away when sat on a table—but yeah, finding the right case is a painstaking process we didn’t ask for!
Skip the numbers and match by model.
Go to Apple’s site or Settings, then General, then About, and confirm it says iPhone 12.
When you shop, filter by exact model name, iPhone 12, not series.
On Amazon or similar, open the Q&A and Reviews. Search “iPhone 12 fit” to see if buyers report gaps or loose fit.
Pick a case with photos of the bottom and camera side. That shows port and lens alignment.
This avoids measuring errors and typoed specs.
