What's the best ad blocker for iPhone?
I’ve been getting bombarded with ads every time I use my iPhone. It’s really annoying and disrupts my experience, especially when browsing the web or using certain apps. Can someone recommend the best ad blocker for iPhone that actually works and is reliable?
Getting bombarded with ads on iPhone can be super frustrating! I’ve tried a bunch of ad blockers and one that stands out is ‘AdGuard.’ It’s got a solid filtering engine and blocks ads effectively across browsers and apps.
Alternatively, you might want to try ‘1Blocker.’ It’s very customizable, and you can tweak what gets blocked and what doesn’t. Some people like ‘Brave Browser’ too, which has a built-in blocker, but if you prefer to stick with Safari, AdGuard or 1Blocker should be your go-tos.
Another good option is ‘Wipr.’ It’s lightweight, easy to set up, and doesn’t require a lot of tinkering. Noticeably reduces the number of ads loaded, which in turn can speed up your browsing experience.
Remember, while these apps work great, ad blockers might sometimes cause certain web pages to malfunction or not load content correctly. You might need to whitelist some sites for a smoother experience.
Hope that helps!
I’ve used AdGuard before and it’s legit! Blocks so many annoying ads everywhere. But, I gotta say, for those who don’t want an extra app, try the alternative ‘1Blocker’. Super customizable, right! But I’ve found that if you’re looking for something less complex and just want to install and forget, ‘Ka-Block!’ is also awesome, and it’s free on the App Store. It’s not as feature-rich as AdGuard or 1Blocker but does a great job at blocking those relentless ads.
For a different approach, has anyone tried “Firefox Focus”? It’s a privacy-focused browser that also blocks ads and trackers. Might be worth checking out if you’re keen on keeping things simple while boosting your privacy.
However, am not entirely sold on Brave Browser because I’ve had mixed experiences with site compatibility. Sometimes it blocks more than it should, and it gets annoying having to adjust settings for each site.
Just my opinion - sometimes less is more when it comes to ad blockers. Wipr is solid, but I like the broader compatibility of Ka-Block! much better myself.
And yeah, it’s so true about how some ad blockers can break website functionality. Whitelisting some sites is pretty much inevitable if you want the seamless experience. Happy ad-free browsing, everyone!
Hey there, I hear ya on the ad bombardment! If you’ve tried the options mentioned by @cazadordeestrellas and @mike34 and still looking for alternatives, you might want to give ‘Purify’ a shot. It’s designed to be super minimalistic and focuses purely on ad blocking without a bunch of extra bells and whistles, which might actually keep things running more smoothly for you.
Pros of Purify:
  • Lightweight and minimal impact on your device’s performance.
  • Simple interface, so pretty much install and go.
  • Efficient in reducing data usage by blocking ads.
Cons of Purify:
  • No advanced customization options that some other blockers offer.
  • Might not catch all the latest ad scripts as well as more robust blockers.
Alternative competitors like ‘AdGuard’ and ‘1Blocker’ indeed have more extensive features but sometimes you don’t want to fiddle with settings forever, right? So, Purify could be a nice balance.
One thing to consider though is that running these blockers could sometimes cause legitimate parts of a site to not load correctly. If you run into that, keep a mental note of sites you might need to whitelist.
Lastly, just my take but avoiding the browser-switching conundrum is why I stick with Safari-compatible blockers. Browsers like Brave and Firefox Focus with built-in blockers are great and all, but if you’re already deep into the Safari ecosystem, those can be kinda redundant and a hassle.
Stay ad-free!
Try switching some habits instead of adding more blockers.
  1. Use Reader View in Safari for articles. Tap the text icon in the address bar. It strips most ads and clutter.
  2. Turn off notification permissions for noisy apps. Settings > Notifications, then disable the worst offenders.
  3. Remove ad heavy apps and use their websites in Safari with your existing blocker.
  4. Use Screen Time limits for apps that spam you.
These steps cut a lot of junk without new tools.
